scz71864 Posted April 23, 2012 Posted April 23, 2012 Iv got a BB tune and i have been reading about the servo mod? can this been done on the nnbs silverados? or should i leave it be because of the tune? seems like a cheap and easy mod.
txab Posted April 23, 2012 Posted April 23, 2012 You can do it. Many have. You'll more than likely need your tune tweeked after the install
kstruckcountry Posted April 23, 2012 Posted April 23, 2012 What is the advantage of a Vette servo vs regular? Just faster response?
GMstrong Posted April 23, 2012 Posted April 23, 2012 the vette servo gets rid of lag in between shifts and firms em up a bit,For 20 bucks and how easy it is to install its a great upgrade.
music Posted April 23, 2012 Posted April 23, 2012 To clarify, a "vette servo swap" only applies to the 4L60/65/70 (and older 700-R4) transmissions, and only affects the 2 / 4 band apply.
scz71864 Posted April 23, 2012 Author Posted April 23, 2012 its supposed to clean up the shift from first and second. can anyone else confirm if i will need a retune if i install?
txab Posted April 23, 2012 Posted April 23, 2012 You want a definite answer? It really depends on what it shifts like after the install. I didn't re-tune, 'cause Justin knew I was going to install it. He hit right on the mark. You PROBABLY will need shifting and line pressures adjusted somewhat. Install the thing and see how it drives
2010LTZ4x4 Posted April 23, 2012 Posted April 23, 2012 To clarify, a "vette servo swap" only applies to the 4L60/65/70 (and older 700-R4) transmissions, and only affects the 2 / 4 band apply. X2
09Brian Posted April 24, 2012 Posted April 24, 2012 Will that eliminate the converter holding the lockup for about 60 seconds when I stop at a stop light ?
kstruckcountry Posted April 24, 2012 Posted April 24, 2012 For that price it sounds good. What's the best place to pick one up? Sooner or later I'll bite the bullet and have BBP do a wire tune... No way they'd come here for an in person lol
GMstrong Posted April 24, 2012 Posted April 24, 2012 Its actually better to do the servo before a tune because usually the tuners add line pressure which stiffens shift points that plus the servo=a unhappy DD.
txab Posted April 24, 2012 Posted April 24, 2012 Does it hurt if I don't retune? No. But your shifting, etc might be better after getting tuned for the CS.
Jennabear Posted April 24, 2012 Posted April 24, 2012 I would recommend you send us an email so that Justin can check your logs. He can see the pressures and let you know whether or not you need an update. Honestly, every vehicle is different, some will shift violently with the servo, some won't- we can get you taken care of either way.
