Another steering clunk issue
Hey guys, I am certain that this plaguing issue has surfaced many times. The dreadful steering clunk issue that is caused by the intermediate steering shaft. Well, I replaced this shaft on my 02 Sierra 10K miles ago and all was good until a month ago.
Now, the clunking issue has returned. I pulled the shaft and found that it it VERY tight and doesn't seem to be any movement between the two pieces.
I was planning to install a grease fitting on the shaft to make it easy to grease, but the shaft seems to be fine.
Any ideas about this issue?
If I recall there is no place you put a grease fitting on the ISS that would solve the problem with the shaft. If you are getting a clunk and it's not the shaft I'd start looking at your entire steering system....
Ball joints
Tie rods
Pitman Arm
Idler Arm
Hub bearings
Loose lugs
Just some ideas off top of my head.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
