Help with my signature
I can't get my picture in my sig to resize smaller... as you can tell its far too large. I have tried resizing it in photobucket... It just will not cooperate. Suggestions?
Photobucket has the software to resize it, are you going to the right area in there? As a suggestion from a artistic standpoint is maybe finding a cleaner background and more lighting since there is a lot of shadow on the truck since you want to use it as a banner. Shoot me a pm if you like and I can resize it if you want to do a new pic, in the mean time I cropped yours and downsized it.
Heres a quick chop i did..
If u want to use it, Save it to your pc and upload to your photobucket so in case i delete it dosent disappear ..
i make sigs all the time on another forum if you want something in particular let me know
Hey Sarah would you mind making one up for me?
I took a stab at it for ya.
Chose my 2 fav pics of your out of your album.. Although that old chevy p/u of your moms is aweosme too!!
Thanks a lot guys I appriciate all the responses. When I get a better picture I will contact one of ya'll as I do not have the patience for this stuff.
That looks sweet thanks:) sitting on water a little odd wish my truck could do that Haha thanks a lot
No prob. If you want to use different pics on a diff background, just let me or sarah know.. I dont want to steal away her offer :D
Sarah , I like your new sig except for the license plate bracket :lol: So i chopped it out for you.. Some reason when i copied the pic , it made the background black tho... Truck looks awesome with it removed tho.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
