Yep. $125 option from the factory or $850 to add it yourself.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Strangely cheaper to add to a GMT 900 than get from factory who would have thought. What a switch!
Sent from my Nokia 5190 using Tapatalk 2
On the 800 they had to do the DIC and steering wheel controls upper buttons are for the radio and the lower is the DIC. It ran closer to $1000 because of the adapter for my aftermarket radio.
Never mind ill just get ss gauge cover and call it done
My good refuses to open and I'm quite pissed
Sent from your truck via Tapatalk
Edited by SarahsGMC
You need a 6.0 cluster before you can get the SS gauge face
I don't need one. I have my tablet that does more than a scangauge. I use the doc when going out of town just to see how efficient I'm running. It passes the time. I play around with it ans see how much dropping 2 MPH will raise the MPG.
I know. But my point was that with her having a smart phone that she can do all that with the right app
You can get knockoffs that look similar. I was never a fan of the overlays though, never seen one light up evenly or normally but I'm picky about that stuff.
Well mine is the GM part. It replaces the factory piece.
Well there is a difference in an overlay and the factory faceplate. mine replaces the black one
Wow that's a lot of work and $ for DIC install on the 800s. Its only about $70 on the 900s and takes about 5 minutes. Wish they made something like the SS cluster for the 900s though.
Sent from my DROID RAZR using Tapatalk 2
The SS cluster does look pretty good. I liked it a lot more than the Escalade cluster. I really dislike when the cluster is in 20 MPH increments. If I install one it has to be in 10 MPH increments. That's why I went with the SS cluster.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
