Just gonna try to get some new waxes & try em out.
I never saw any at Advance before.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_7110036-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-7110036&ci_src=17588969&ci_sku=7110036&ci_gpa=pla&ci_kw=&gclid=CNbZge7UubcCFYKd4AodkEUALA
I get about 4-5 months out of a coating and my truck stays outside year round.
Edited by BruceDeuce
I put a U-Haul Tow Hitch on my truck today.
When's that cooler going on?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Just got the fitting today. Leaving to go camping for the weekend so Im headin up the honeydoo list before I go. Will do the Cooler next Monday or Tuesday. Believe me you will know as I will seek your experience with this.
I changed the plugs and wires today. #7 plug didnt look too great
Did it fix your issue? Sent from a jelly bean.
Not sure, Sent you guys a misfire log after I got it all done around 6:30. I also sent a couple pics of the #7 plug since he said that's where the misfire was. I hope this fixes it because I have to drive to Fresno tomorrow.
I am hoping it fixed it or you guys can point me in a different direction. Old plugs were NGK TR 55's. I put in Delco 41-110's
Edited by chawkins6789
I dont have a gap tool nor do I know if they were new or not. Not sure that shop cared much about me because I wasnt a big money customer. he tried o sell me on spending more money by stroking and adding a Procharger F1 to it but I had a tight budget
That stinks. Those NGKs are good plugs though, so hard to see them just going bad. Justin will check out your log for you.
Ordered a Or-Fab DEF Skid Plate, not going to pay to fix GM screw up again!! I hope. :jester:
That stinks. Those NGKs are good plugs though, so hard to see them just going bad. Justin will check out your log for you. Sent from a jelly bean.
I know he will. Love the customer service from you guys, Wish you had a shop i could just take it to and have things done
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
