Also cleaning up BruceDeuce's new transmission cooler
Yeah man lookin good. That new cooler you have there is atleast 1 1/2 thick right> Real nice!!!
The new one is 2.75" thick. I'll have it mailed out tomorrow. Its packaged in bubble wrap. What you see in the pic is what you're getting. Cooler, hose, hose connectors, and clamps.
Thanks Chris, Im looking forward to it! Hows your back must have been given some shit earlier. I dont ever see you overheating your tranny again with that cooler!
Went & got my new muffler & tip put on today
You know you got to show us :idiot::lol: I've been needing to relocate mine ever sine putting the BL on, lets see it.
It hurt yesterday after the radiator swap. So I went to the local hydraulic shop and had them do it
Ahhh I know man! haha
I'll try to take pics tomorrow. Dad lost my SD card, I gotta buy one :(
Truck is all dirty :(
Just did a little more work. Played with power tools.
Fun Fun
I had to make a bracket so here is a before and after
Before:
After:
I bought a piece of 36"x1"x1/8" Aluminum (gotta save weight :crackup:) flat bar at Home Depot along with some 5/16" bolts, washers, lock washers, and nuts to make a top bracket for the cooler. It was only bolted on the bottom.
So rush hour with the new cooler in the morning. We will see how temps go. Also afternoon rush hour on the way to class tomorrow evening
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Fun Fun
Before:
After:
Looks good! I guess your back is better :thumbs:
My back is never better, but I have a 2 hour drive to class tonight and I wanted it secure. There and back in 1 day is 250 miles.
Oh I'll drop that box off at the post office when I get done at the dealer and get you a tracking number if they give me one
You should post a mod thread giving details with part numbers and such for people who are interested in doing the same or similar swap.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
