My day today
More tomorrow.
Lol no offense but he's right haha
Sent from the back seat of your truck
Some people have school and doctors appointments to clean and clean like you do Sarah. My fans were pulled from the been of a junkyard truck. If you all have a problem with its cleanliness then fly out here and detail it because I sure as hell won't be doing
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
  • Like 3
Someone is snippy today :lol:
Ryan
Rolling a 2013 camaro ss vert for the week. Just a little different than the Nali!
Sent from a jelly bean.
Be careful it might end up being more than a week
Ryan
If he wants to start something here isn't the place to do it. He got sent a pm
no issues! didnt mean to come off like that, my bad
Its fine. Just a long shitty day and it's starting over again
Sounds like you need a cold one chris
Sent from my SGH-I927 using Tapatalk 2
Except I quit drinking
No one likes a quitter
They do when it causes health problems
Hell the fans are going to get dirty again anyway. I dont detail my fans I have a life :chill:
Cooler is off bruce
Well here are pics of it.
Mounted
Braided Teflon -6 hose used from transmission to radiator to cooler and back to radiator
Pressure line on
Installed
After about 30 mins of spirited driving
Gauge is a touch off
Found the Mini Me to my truck
Edited by chawkins6789
Also cleaning up BruceDeuce's new transmission cooler
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
