Yeah Im waiting on the fitting I ordered, should get it Tuesday or Wednesday. Thanks again!
Normal engine fan I dodmt run an aux fan for it
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Loaded for a dump run
Ryan
I need to make one of those. Clean out my garage.
Rotated my tires
Dug this mud out of the cup where the U-Bolts go through
Sprayed off and put on a coat of collinite
Ryan
I replaced my door!
And now I have saggy hinges :(
So now I get to replace the hinges!
It's been 4 LOOONG months of passenger-side crawling...I really appreciate having a working driver's side door now though.
Sag or no sag, it opens!
Edited by Davidsingletary
Dunes and drinking the past 4 days
Me and my boyfriends rigs
Sunset
Most of us
Doing what I do best
Boyfriends Yukon
Got the truck back from the body shop, looks good, didn't take any pics yet, been busy all day workin on the wifes car and the truck.
Sprayed off and put on a coat of collinite attachicon.gifImageUploadedByTapatalk1369621322.253630.jpg Ryan
Ryan where do you get your Collinite Wax at?
I know their like 5 different ones?
How does it compare to Americana?
I use the 845, best durability of anything I have used
Autogeek.net
Like $15 a bottle
Never used Americana so I cannot comment.
Ryan
I use the 845, best durability of anything I have used Autogeek.net Like $15 a bottle Never used Americana so I cannot comment. Ryan
I use the 845 as well and get it from Advanced Auto Parts.
Just gonna try to get some new waxes & try em out.
I never saw any at Advance before.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,122 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
