Not much. Rained most of the way down and back, then the last four or so hours I got hammered. Didn't even try to keep up with the wipers. Quite a chore at the carwash. Going to do the All American Sunday tomorrow at the GoodGuys Heartland Nationals, had to get it a little, okay alot, cleaner.
I have a leak in my washer fluid reservoir, So I made it to Nevada and it was empty
Replace eventually
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
If you can reach the hole or crack some JB Weld quick putty might do the trick for now or for good. There's a bunch of different things out there, but a wad of that will get into tight spaces with no applicator, tube or caulking gun required, just a couple of fingers.
I think it spit qt the seam around the bottom.
How fast did you drive for the better mileage Jon? I've found with my 3.73 gearing that I lose 2 mpg (depending on wind) bumping from 70 to 75. 18 mpg is what I get on most long trips.
Cleared my 0446. Hasn't come back yet.
3.73 on a nnbs 4x4 Tahoe isnt a good combo for MPG. Best Ive seen is mid 16s at around 70 mph Edited by SnakeEyes 325is
My stock 5.3 got mid 20mpg on the trip to mytrle beach. Some of it really seems to be the gas. Any time I fill up outside of ohio I get better gas mileage.now sure how you far west guys gas is I have never been past Chicago lol
Sent from my SCH-I535 using Tapatalk 2
70-75 mph. Fueled up mostly on BP ultimate(93). I found about the same, 80-85mph cost me 3mpg, or over 75 miles per tank of fuel. 16.9 mpg with a supercharged 6.2 makes me pretty happy. Cleaning off bugs doesn't. - Jonathan
Edited by SILVERADOSC540
We'll see in a couple weeks how much switching to premium helps my mileage.
Took down my evap canister, cracked it, blew it out and cleaned the "filter element" (aka sponge). It was a mess, I wish there was a way to bypass it. Hadn't thrown a code since I cleared it earlier though.
Shit my truck just got hailed on it was small in size but there was a lot of it. Came out of nowhere the sun was still shining.
I'll look at again when the sun is out tomorrow but I didn't see notable damage earlier.
Sent from my DROID RAZR using Tapatalk 2
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
