Either way it would have hit guard rail. For some reason, coming off that overpass the guard rail goes into the left lane about 6-12 inches.
Here are some crappy night pics of the damage
Im more pissed than anything. I was going to take a back road because of construction in the area. I didnt do it because I thought that it wouldnt be bad on a Saturday night. Looking at $800 in parts before prep/paint/install and cab body work. It will be a while before ita back to being nice and shiny. Im glad it hit on the left instead of the truck hitting the right because I had a passenger.
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Kept going
Sent from my Samsung Galaxy S4 using Tapatalk 4
What a dick! Any chance your insurance will cover it
Sent from my SGH-I927 using Tapatalk 2
Most likely, but I am not going to use my insurance. I am going to piece it together slowly.
Took the kids to the park
Ryan
After having tow mirrors for a couple years, the DL8's suck. They are so small. But, I have working mirrors again
Got my Zone 2" blocks installed on the front. I'll do the back next weekend.
Trying to get the second row screen work when the truck starts. Audio only from the dvd. Head over to
http://www.gm-trucks.com/forums/topic/153527-urgent-rear-seat-entertainment-screen-issue/?do=findComment&comment=1355060
To read full issue. Its odd.
Puttin around branson. Got 14 mpg from SE of tulsa, east through arkansas ozarks on 412 then north up to branson on E85. Seems decent?
FYI....not really anything to do with twin 1 year olds Branson.
Edited by SnakeEyes 325is
Im more pissed than anything. I was going to take a back road because of construction in the area. I didnt do it because I thought that it wouldnt be bad on a Saturday night. Looking at $800 in parts before prep/paint/install and cab body work. It will be a while before ita back to being nice and shiny. Im glad it hit on the left instead of the truck hitting the right because I had a passenger. Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Chris, just confirm you and your passenger were uninjured, (not counting pride). That this was strictly PDO (property damage only???). Sorry to hear it happening to the world's best/most modified truck. I know you'll bounce back better than ever from it. Hang in there! Glad you're OK!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
