I couldn't find them at Auto Zone when I was buying my oil. By the way if you need to stock up on oil 5 qts of M1 EP and an M1 filter is just $39.99 there right now
Sent from my Samsung Galaxy S4 using Tapatalk 4
Thanks, I've been using plain M1. I might grab some soon, I only have about 4k til my next oil change. But as many miles as I've put on lately that might not be til 2014.
I'll rack up 4k by mid November
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
5k since July, 10k since may.
Picked up an extang blackmax bed cover on the super cheap!
Sent from my iPhone using Tapatalk - now Free
got one on my truck too. Great cover and has held up very well for the three years I have had it.
Good to know. I got this one for $20 since it has two very minor tears in it. I'm gonna see if I can get it fixed by an upholstery shop or try to collect on the 10 year warranty these come with.
Nice cover. I have the Tuff Tonno, but I think next time I'm gonna go with one that sits below the bed rails.
I pulled my bedliner out. I gave it to my friends dad for his 03 Silverado. It was less gas to do that than to go to the dump.
I have put a little ove 1800 miles on the truck since last Tuesday, and next Monday will make about 1800 going home!! :jester:
Todays work. My bedliner out and installed in an 03 Silverado
How my bed looked
Installed in the silverado
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
