yea still a layer left on. Needs a good wash down, just hot water will not take it all off
Well as luck would have it, I broke the hard line for the washer tank. I may have to get a new one, or I think the 1/4" poly line that we have at work may be the same size. Grab a quick connect union at work as well and all should be good
Sent while drinkin' a cold one...
Let's see.... Today, I went to Line-X and got the bed sprayed. Then I installed my Fold-a-Cover tonneau. Then installed my GM led cargo bed lights.
Tomorrow I'm going to change the oil - only have about 1200 miles, but like to get rid of the break-in junk. Plus Advanced Auto Parts has a BOGO on Mobil 1 Super Synthetic - getting 10 quarts for $37 w/ tax. Will pick it up at the store tomorrow.
Just rammed into a girl leaving walmart truck was not stopping at all and of course the light was red so I bumped her.. truck took no damage lightbar saved the day again. Busted two lights but they still work lol. Didn't get in trouble either because they didn't want cops involved even though i dented their blazer and busted the tail light.
Sent from the toilet
You faired better than ironman tonight
Ryan
16 of them are in Indy. Took my 4 yr old to see em. Fun time
I am also a proud new owner of 2 copo camaros
Ryan
Monster Jam is in Little Rock also today. Grand son asked to go but he waited until today to ask and I did not want to sit in the nose bleed section so I told him to ask before the day next year. :jester:
Monster jam was here recently
Edited by SarahsGMC
I believe monster jam was here this past week or last week at the Verizon center in Washington, D.C.
Went to the gym/home depot and out to dinner. Big 35mile day in the truck; loved every mile....just over 1500 now.
Sent from my DROID RAZR HD using Tapatalk
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
