Im not running e85 ryan. And how do you feel about leading the totm nominations
That was running 4wd using the remote start to warm up the truck and E85 usually get around 11
Ryan
Yea I pull 9 with no 4wd, remote start, or e85
Wait, what?
According to build your own on Chevy and GMC sites, they only way to get rear seat entertainment on the trucks is with DENALI ? Not even on Chevy or other trims?
Edited by SnakeEyes 325is
I get bout 13.5 round town, hand calculated when I filled up the other day. Put on about 220 miles Friday as well
Sent while drinkin' a cold one...
I filled up with some pure gas. For some reason the shutoff kept acting like the tank was full, could go maybe 3 seconds before it shut off again. I think it was just a faulty handle.
The Marathon right by my apartment sells ethanol free gas. Been running that instead of E85 since before Christmas to help get decent range off a tank of gas. With as much as I use the remote start in this cold and then only putter around town I'm not even breaking 13 MPG currently. I bet E85 would be single digits.
I'm right at 11mpg with a full 20 min. AM remote start run time and about 10 min. PM run time. 11.7 DIC and 11.0 by hand or scangauge II
Edited by SILVERADOSC540
Today was day 7 of the building of my new house! :) This is my first house, and my wife and I are expecting a baby this summer! Things have moved fast for the house, last Friday we started breaking up the frost on the ground, (its been -40 here) and Monday we dug the hole. Monday night was the footing pour, Wednesday afternoon we poured the walls, today we poured the garage footing (hehe my first garage :):):) )
and also got our septic tank in. Next week the floor goes on, needless to say we are excited!
Photobucket wont cooperate tonight so pics will wait!
Looking to build a house here in New England maybe next year. Sounds like yours is coming along nicely!
Sent from my DROID RAZR HD using Tapatalk
I think this spring I'm going to pull out a loan (pending on how much it is) to get all the rust repaired on my truck, pull the dents, and get a good paint job. Of course its going to be black again
If I ever get around to repainting mine I'm going to have the entire truck done with bed liner
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
