Washed it yesterday. Luckily got high enough above freezing.
My 16 month old twins are starting to race around in their power wheels. They havent got turning figured out quite yet, so when they run into something they just wait(or yell) for me to turn them around. Gets very tiring....
Woohoo heat wave
Truck parked at work
Ryan
Heat wave? Do you want to see my temp?
No
Ryan
No
Ryan
Subtract 5 then multiply by 3
Woohoo heat wave
Ryan
Should have drove the camaro hehe
Sent from the side of the road...
Ryan what is that black stuff your truck is parked on? It's currently -9 here so salt still doesn't work everything (parking lots/roads) is covered in packed ice and snow
Did a walk through on the new house today
In the garage?
Ryan
Came home to this. Packed hard snow blocking the drive from the plow jerkoff
Got it in the driveway
My wife pushed a ford truck out of the snow today. Guy got stuck in our subdivision. I am also proud of her because she listened to me. I told her if she is stuck in snow turn off stability control. As she was pushing his truck it lost power she said is your stability control on? He goes the little squiggley lines she was like yes turn it off. He then got unstuck
Wife 1 ford truck owner 0 haha. Read your manual people!!!
Ryan
Same thing happened Monday. I helped the grad student I was working with at UM dig out his car and I told him to disable the traction control. He said ok and started driving while a few of us pushed. I heard the engine cut so I just opened his door, pushed the disable button and a few good shoves later his Kia was out of the snow bank. :lol:
I tried to push this Acura tsx out of my snowy driveway and traction control was not letting the wheels spin and I couldn't shut it off, there is only a button that says VSC to something like that but it would not turn off.... Had to pull it out
Took the truck out to get pizza and stop at my buddies house to pick up a case of Yuengling that he brought back from PA. He says itts pretty darn good. Ive never had it before so we will see.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
