You can keep your weather Chris. I'll take my duffle bag full of PMags. :lol:
A got a few of those. With the help of my drill they can hold the same as yours
My truck is getting me through the winter Apocalypse.
Sent from my DROID RAZR using Tapatalk
Coldest morning we've had in a long time. Sat there and listened to my truck idle really rough as it warmed up then scanned it and got a running lean code. Only does that on super cold starts. Then used it to jump off our car. Neither liked the weather apparently
We are snowed in, county is under a travel emergency. It's. -14 now with a wind chill -40 sucks
Ryan
Ain't that bad here it was around 12 this morning which is COLD for south Arkansas
Got the truck washed this morning. Had to use the last of my emergency dexcool
Pistol class sounds like a great weekend to me!
Sent with Tapatalk powered by Droid
Edited by loganb
Ryan I know it isn't exactly your area but I had to cancel my Chicago trip because I94 in NWI was closed. Hoping to get out Wednesday now.
Heck it was -29 here yesterday and -20 all day today plus a 40 mph breeze lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
