Best mod I made to my car
Ryan
1 3/4" tubing with 3" collector and 3" off road y pipe
Sent from my SPH-L720 using Tapatalk
Installed my new to me weathergaurd toolbox in my truck bed. Now my tools for work wont be flying around the cab anymore.
IMO- 1 3/4 and 3'' collectors are a little big for a 5.3. hope you don't louse to much at the bottom end..i would have gone with 1 5/8 with a 2 1/2 collectors, but that's just me..good luck with them..
Time to party
The o2 sensor holes are for nothing but show, if you dont have a tune with 02 "delete" youll need one to turn off the light.
Other than that, I love my LT's.
Edited by SnakeEyes
I might need to take it back and have the tune tweaked anyway
When I got my pacesetters, I talked to Justin about re-tuning the truck and he said I didn't need to, the second set of 02 sensors didn't matter and I just disconnected the rear sensors and everything worked fine with no codes.
Ok, not so big on siiting on hot leather when I finish work....going to have to start remembering to use remote start. But enjoying it. Been wanting a truck again for a daily for a while, and now its my only choice!
Guy at works see me and says "Hey, I thought it was Black!"
Edited by SnakeEyes
I think when there's a code thrown, the remote start stops working. This happened to me when the truck was new. Ended up some code that resulted from me starting the truck right after I took it off the charger - had a DIC message about overcharging. Then the remote wouldn't work until I had them wave the magic wand over it under warranty.
My truck is still at the body shop. Fine with me - I'm taking my 41 year old 2-stroke motorcycle to Laconia Bike Week tomorrow morning. I won't miss the truck one bit. :)
Thinking about ordering a new dash again, but think I'll wait until that crack spreads (still in a mostly "blind spot")
Just sprayed my rear floor mat off at midnight after an unfortunate event with my sister happened. Clearly she is a lightweight and can't hold her wine lol.
Weathertech floor mats are the best investment I've made in both my trucks so far! Couldn't imagine what that would have done to the carpet if I didn't have it back there!
Washed it was way overdue
Ryan
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,305 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
