Went to homedepot to get some carpet razor blades and a scraper to tear up some flooring
Sent from my ADR6400L using Tapatalk 2
Needs a bath :(
Have some new ONR with carnuba I just got and want to try out
Ryan
Rosco - makes a huge difference in the engine bay doesn't it?
Ryan
It is, even better the truck has only 27k miles on it!!!
Damn that engine bay Is filthy :)
Ryan
Runnin across Michigan first stop is bass pro shop in auburn hills for lunch and then to my friends place for shenanigans I'm about 45 mins away from there now this truck is so nice to travel in
Sent from your truck via Tapatalk
Put 40 bucks worth of gas in my tee-ruck. Man this thing likes to drink gas but I love driving it !
Sent from my smartass iPhone using Tapatalk
Dropped the 300 amp alternator off at FedEx. Its going to the manufacturer in Riverside, CA to get the wiring harness changed.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Bath
Ryan
Wanna do my truck? It's filthy from the 2000 miles I've done in the past mine days.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
