It has been in my livingroom for 2 years. I got tired of it sitting there not being used
Looks like it's in the perfect place now.
That thing is mint!
Only light I have is a Coors Light ... neon light in my laundry room. :D
That thing is mint!
I have that same washer
Nice. Thing has been good to me over the past 13 years.
Only had to fix the gray boot in the door that leaked water for years (got torn somehow), and I had a piece of foam fall down inside the unit, and trip the out-of-balance switches prematurely, so it would never get through a spin cycle. Came back one day to find the thing still running 5 hours after I started the load. Thing has trouble codes like a modern car, lol, only 100x more simple.
Also have the matching dryer - all that I had to do to that so far was grease the rollers for the drum to stop the annoying, rhythmic squawk it used to make, lol. Lint trap sucks - it blows lint balls all over the lawn ...
I have matching dryer and stand. I think mine are 13 years old
Getting mine inspected at the dealer I bought it from six months ago. Want to get the inspection done before the headers, Y-pipe and tune done over the next two weeks.
Exact same as mine - we must've bought them at the same time. I wrote the date on the back with a Sharpie - 7/12/03. Hauled them here in my '72 El Camino.
We don't have the stand though - that's something I should have got. Our floors are uneven in the house, so the washer goes walking all over the place after a spin cycle. Been dealing with it forever, so guess I'm used to it now. Thing sounds like a jet taking off when it spins, lol - think it hits 1,300 RPM if I remember right.
Edited by Jsdirt
Did a half turd wash job on the beast yesterday. Need to redo the passenger side, I let the soap sit too long, windows look like crap. At least it's somewhat cleaner than it was though. Also added some plastic stuff to the headlights so they don't yellow again. Need to remember to do that every month.
Got a little close to a field parking at an auction. So moved to the over side of road.
20160507_132756_zps1l4goq3y.jpg?w=480&h=
20160507_132806_zpst7lxbtzq.jpg?w=480&h=
20160507_132817_zpsajrjtrzh.jpg?w=480&h=
Lots of weight for gravity to pull on there. :)
Love that flatbed - real nice!
Edited by Jsdirt
What is happening to that running board chevyguy
Sent from my SM-G925V using Tapatalk
^^^ Can't believe I didn't even see that when I first looked. Got some ramp action happening there ...
6eeab05e2ec4576376880f8fbccd4361.jpg Edited by Chris
Nothing. When grandma was alive it was hard for her to step up into her '06 2500 (she was around 4' 10") because the running boards hug the cab so much, so dad took some metal blocks, drilled holes in them, and dropped the running boards down and moved them out so grandma could actually get her feet on the running boards instead of just her toes. I didn't need that when I took over the '06 so dad took them off and put them on his '09. I'm just too lazy to take the blocks out. I think there's a spare set of blocks somewhere, or at least one or two in the garage somewhere. I think the blocks make the back half stick out more so dad could stand on the boards and reach into the tool box. If that's not what you're talking about then I have no clue.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
