2010 Silverado LT: which leveling kit to use for 20" rims w/275/5
adostall01
Hello! I am buying new rims/tires for my 2010 Crew Cab LT (not a Z71). It has the stock 17's on right now. I would like to go with 20" rims with 275/55/20 rubber, but I am told I need a 2" leveling kit. This brings me to the following question. Should I buy the 2" leveling kit or go with new adjustable shocks? The leveling kit is less expensive, but I don't want to feel like I'm riding on a hay wagon, either. Also, do you recommend lifting the rear at all?
I have also been looking at going with 18's and 265/65/18 rubber. Would these fit without any suspension tweaking?
Thank you for any information you can share!!!
Allen :)
No level needed for either I believe. Both are stock sizes. I have a 2004 with 2.5" and I run a 275/55r20 and I have plenty of room
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
The overall tire sizes will be close, wheel size means nothing really. Bigger hole in the rubber does not make the tire larger, no kit needed.
Sent from my iPhone4S
using Tapatalk
I'll echo the others. You don't need a leveling kit. If you choose to level, it's up to you which direction you want to go. I would stick with a cheap spacer, as there is virtually no change in the ride.
Sounds like he needs some training or a new job. Then again, you only need common sense to know something as simple as that.
