When to use tow mode?
I have a 2001 Suburban 1500. I'm wondering when I need to use the tow mode while towing. I know it's not needed on very light loads (small utility trailers, etc...). Is there a weight limit of which requires the use of tow mode?
Straight from my owners manua (2006):
Tow/Haul Mode
Tow/Haul is a feature on automatic transmission
equipped vehicles that assists when pulling a heavy
trailer or a large or heavy load. See Tow/Haul Mode
on page 2-31 for more information.
Tow/Haul is designed to be most effective when the
vehicle and trailer combined weight is at least 75 percent
of the vehicle’s Gross Combined Weight Rating (GCWR).
See “Weight of the Trailer” later in the section. Tow/Haul
is most useful under the following driving conditions:
• When pulling a heavy trailer or a large or heavy load
through rolling terrain.
in stop and go traffic.
in busy parking lots where improved low speed
control of the vehicle is desired.
Operating the vehicle in Tow/Haul when lightly loaded
or with no trailer at all will not cause damage. However,
there is no benefit to the selection of Tow/Haul when the
vehicle is unloaded. Such a selection when unloaded
may result in unpleasant engine and transmission driving
characteristics and reduced fuel economy. Tow/Haul is
recommended only when pulling a heavy trailer or a large
or heavy load.
Thanks for the post. Any idea what my truck's GCWR is?
Unfortunately I do not have that kind of information at my disposal but if I were to make a guess, I'd said around 13,000 pounds. That is where my truck is rated at so yours can't be too far off from that.
It really doesn't take too much weight before you hit the "magic" number considering about half of the GCWR is the weight of your vehicle right off the top. Best bet is try it and see how you like it. Certainly won't hurt your rig any. I always use it when I'm towing regardless of the weight involved. I've also used it sometimes just driving around town not towing/hauling. I prefer how the trans shifts in town with tow/haul engaged plus when really want accel power it's just a matter of more pedal and don't have to wait for the trans to decide to shift first.
Found it. Curb weight is 4,914 lbs. And GVWR is 7,000 lbs.
So, I shouldn't need to use it for a 2000 lb. pop-up camper and 700 lbs. of people and gear, right?
Probably not, but again, you can always try it to see if you like how it handles. If you find that the trans is shifting a lot or is engine is running hotter than normal, tow/haul will help out a lot. By holding gears longer and not letting vehicle shift up into overdrive as early it'll save some trans life.
The GVWR is what the vehicle can handle by itself...towing a trailer is a different set of ratings, that suburban should be able to tow 6-8,000 lbs
I use it anytime I'm towing around 1000lbs or more. It doesn't hurt anyting to turn it on, even if not needed.
I do the same anytime i have around 1000lbs or more in the truck or being towed i turn it on i think it helps, but it is all personal feeling to an extent.
  • 5 months later...
A little known function of the tow haul mode: engaging it will change the turn signals "tap" from 3 to 6.
Sent from my Nokia 5190 using Tapatalk 2
I dont use it unless i have 4000 lbs or more, including trailer, myself, passengers, and cargo or I am towing on rolling terrain or steep grades
