a/c issue, works for a while
04 Silverado Ext. 5.3l
Manual Dual Climate Control
Early summer i had my a/c leak tested, evac'd and filled. It had been running poorly (barley cold). No leaks were found but the system was low. I tested it out after the fill and it seemed to cool nicely, but, and this is just a seat of the pants analysis, it didn't seem as cold as past years. I don't use the a/c much, usually only when the wife and kids are in the truck with me, so when i say this problem seems recent, it could very well be since the system was re-charged. Basically the a/c stops cooling after a while, sometimes 30 mins to an hour. It doesn't blow heat, just becomes ambient, musty and damp, on both the passenger and drivers side. I can switch the sytem off, keep driving for 5 mins, switch it on and it will cool nicely. If i don't turn it off, it doesn't start cooling again, at least not within 15 mins. This has happened a few times, driving in heavy stop and go traffic as well as on the highway, pulling a trailer or not. I'm going to bring the truck back in, the shop said they'd pressure test it again but i was wondering where else i might look for a problem. Two other thing i've noticed, my recirc door actuator doesn't work, the button stays lit but nothing moves, and it seems like i don't have huge puddles under the truck on really muggy days like i used to. I can lift the hood and condensate is dripping out the line, but not a whole lot.
Any help would be appreciated.
Ad
I'd check actuators and check to make sure the clutch is engaged during the periods where you seem to be not getting any cooling
It sounds like it's freezing up after continuous operation. Maybe the A/C clutch isn't cycling? If it's run 100% of the time, the condensor will freeze, and then you just get cool air until you turn it off and it thaws again.
With symptoms/history like that, I'd be looking for excessively high pressures that build slowly due to air in the system. Yes, even though it was "evacuated" (quotation marks because EPA says that has to happen when the system is opened).
It is possible your AC system may have a slow leak, or even be overcharged. The AC system will not operate if it senses pressures too low or high. If you get a pressure gauge by Duracool from Wal-Mart you can check if pressure is somewhere between 25-38p.s.i is perfect, and no more than 45 p.s.i. I beleive the gauge may need a can screwed on to block off your aéc refrigerant from leaking out. If pressure is low try a can of Duracool which is compatible with r12, and r-134a refrigerant and its $15. If it leaks out, buy the stopleak sealant for $25 works great, and refill system. Otherwise bring to a trustworthy qualified shop to inspect and do it right.
Thanks for the advice, i'm off this week, i'll bring it back to the shop where they did the leak test the first time. They told me to come in anytime and they'd throw the gauges on and pressure test it at no charge. Weird this past weekend, we left for a camping trip friday at noon, hot day, kind of muggy and the a/c would work for 10 minutes then stop, i'd switch it off for 2 minutes and it would work again for about 10 minutes or so, i left it off for a while (maybe 20 minutes) and when i switched it back on it would only run for 10 again. Today on the way home, it ran the entire two hours without a problem, less humidity today though, cooler day too. I'll fill everyone in after i get it re-tested. I'll ask them the pressure they're getting too...@Wolfmanjohn, what would be considered excessively high? ...and i'm assuming its a high measure at the low pressure switch?
Oh, and i've tested all the actuators, they're functioning fine, with the exception of the recirc door. It doesn't move at all.
Ad
A high pressure reading of ~400-450 psi at the high side discharge would kick it off.
  • 11 months later...
First off, sorry to drag up an old post but I figured this is the best way to give everyone the history.
Second, sorry for never updating the post. For the rest of last summer, the a/c seemed to work fine for the few times I used it, i never brought it back in to the original shop.
Enter summer of 2013...I have no a/c at all. The compressor wasn't kicking on. I started by jumping the low pressure switch and it kicked on immediately the coolant line got cold and frosted up, no cooling inside though. I grabbed a new low pressure switch and hoped this would solve my issue. No dice, although I can hear the compressor cycling quickly, maybe about 2 or 3 seconds, on off, still no cooling. O.K., sounds like a low refrigerant situation but I'd like to confirm with anyone that can help. I borrowed a buddy's low pressure side gauge, one of the ones you can grab at the parts store to top your systems up. With the compressor cycling quickly, i would see readings of 50 to 5. I'm going to assume that this proves I have low refrigerant? Do these numbers mean basically empty? If this is the case, I'm thinking about topping it off with duracool or red tek and some leak seal. They don't let us buy top up r134 in stores up here.
Unless of course someone might know better.
thanks
Adam
Fix the leak properly. Don't use the fix a leak crap. Only causes more problems
Sounds exactly like low refrigerant to me. Most common leak is from O-rings. You can buy an A/C O-ring kit for your vehicle for not too much money. You'll need the tools to disconnect the lines to replace the o-rings. Don't forget the ones on your compressor. You'll need to vaccuum it down after this to remove moisture and to leak check. Replace the receiver/dryer while you are in there and add an oz or so of refrigerant oil if you replace the dryer. Another common area that can leak is your schrader valves so hit them with some leak detector or soapy water when done.
Thanks for the replies everyone. The shop last year put dye into the system, I noticed when I swapped the low pressure switch, the valve underneath spurted a little green at me. I borrowed a UV light from work but haven't been able to track down the leak yet. No bubbling from soapy water sprayed either. There's still some pressure in the system so it should still be leaking somewhere. I'll keep looking though, gotta find the leak and change the part before I evac and refill.
Ad
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
