First oil change
I stopped at a Jiffy Lube to get my first oil change in my 2012 6.2L. The clerk called me to the bay to tell me the oil requires dexox spec oil and they did not have it but the syntheic they had would cost $75 so I did not do it. I read the owners manual about this oil for the first time. Is this the standard price for an oil change with oil meeting these specs?
Nope. Go to the dealer, I think I pay like $30. The GM-spec stuff is synthetic blend so it's less money.
I would never take a new vehicle to jiffy lube. Pay the $30 and go to the dealer.
+1 on that, these types of places work on "volume", so you wind up having a high ratio of stripped oil pan threads, or cross threaded bolts into the pans. How do they fix that? why just run a bead of silicone sealer around the bolt.
I purchase my own oil (Mobil 1 extended performance 5W-30), and take the vehicle to a local trusted shop, they charge me $8.50 rack charge and change the oil and filter, plus inspect the bottom of the vehicle, and lube as necessary.
it worked out. Took it to a another place for $30 and included a tire rotation. The problem was Jiffy did not have dexos spec oil and wanted to sell me their shell synthic blend for $75. I said no way and what gets me is another guy with an older chevy sells he pays $75 everytime. Wow!
I just do my own oil changes and save the money. I'm pretty confident that I also do all the same checks the dealers/shops look at for the most part.
Same here I never take my truck in if I know I can fix it
Sent from my truck using TAPATALK
I'm with you on that one! I use Pennzoil Platinum or Ultra, wix oil filter, grease both zerks, check for leaks and all is good. Plus, I love working on my truck! The stealer charges $65 for mobil one.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
