Need your opinions on this brake kit
Looked at this for my last truck. Never purchased, but did read lots of reviews. Some good, some bad. Price is right. Check warranty and or return policy with different vendors and if somebody will take care of you then go for it. Considering a kit for the wifes '06 malibu. Think I read the reviews on AutoAnything.com or stylintrucks.com, not sure.
u can try this too, brake performance.com......if u want something to compare it to! get the coated rotors though!!!
I would go with the "Baer" rotors for cross drilled and slotted.
Thanks for the sight, I book marked it.
It depends on what you are putting them on. And how you use that vehicle? :confused:
From what a lot of people have been saying they warp easy. I will stay away from the cross drilled and look into dimpled. I had a set of cross drilled and slotted on an old sedan and they warped pretty quick.
I have had the Baer "Eradaspeed" rotors (drilled and slotted) on my 2001 Z28 (Sara) for 10 years with no problems whatsoever.
I admit Baer is a brand I think would stand behind their product. Just watch out for lower end companies
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
