NEW TOYO AT-II looks damn good!
sic lsx
I put a set of these on my 2012 GMC a few weeks ago, 285/65/18, along with new wheels. The tires were $258.00 ea. They do make some minor noise but no big thing, I'm driving a truck. They handled great on a fishing trip I went on, no rocks stuck in tread. Don't seem to handle as good as some other AT tires I've had on asphalt but overall, very nice.
Nice any pics?
Look above on my other post. (I'll figure out this posting thing sooner or later)
  • Replies 39
Hey guys - newbie here. Long time reader / lurker!
I'm pretty stoked - my Michelin LTX AT2 are going bye bye and I'm putting on a set of these tomorrow. I found them on TreadDepot for less than my local shop, which I pointed out to him. The guy was really cool and beat their price, so I'm getting a set of these mounted tomorrow morning ($165/ea - 265/70/16's).
Which, btw, I now have a spare set of Michelin's to give away.. .LOL If you're interested, let me know. I'll post pictures of the new Toyo's tomorrow.
Oh my, those look awesome. Wonder the weight issue as well. I'm really considering going from Trail Grapplers to a All-Terrain after my Trails wear out to get a little rolling resistance back. Plus these Trails are around 75 lbs. a piece I think.
It would be tough between these and ATZ's.
ill be running a 0 or +14 offset haven't made up y mind. I want the wheels to work for when i do lift and 35s
Sab316,
Between these, M/T ATZ's and the Nitto Terra's the weight if very close for the size I'm looking at. The ATZ's are a lot more expensive ( more inline with similar mud terrains). The toyo's were suprizing-ly priced fair. I wish I didn't have to get and E load rating for the sizes that I want. Don't need the extra weight or harsher ride from 10 plys.
For reference:
Toyo AT2 35/12.5R20 78.9lbs
Nitto Terra 295/60R20 69 lbs
M/T ATZ 35/12.5R20 71 lbs
Side note: Nitto Terra non- E rated 305/55r20 was only 55 lbs and Toyo AT2's non- E rated 305/50r20 are 51 lbs.
Also taken straight from Toyo's website. Just so no one gets surprised.
Xtreme sizes, such as 35x12.5R18, feature a deeper tread depth and a more aggressive tread and shoulder design.
LT 305/55/20 AT-II is 74 pounds. Wowzas. I think my 295/55/20 (33x12.5) Trails are around 74 pounds a piece. Not much difference.
i pick up these 305/50r20 tomorrow! got them for 224$ each :) good having friends in tire biz
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
