101k miles and just my luck...
I'm all happy my truck hits the big 100k, when my fuel gage all at once goes nuts. I start the truck and I'm at "Low Fuel" and sometimes gage pops up and other times it will creep up slowly. However always starts out stuck at Empty. Check engine light is on and the code according to Advance says fuel level sensor has failed. So I guess I get a chance to check out the top side of my fuel tank sooner rather than later. Nuts!!!
If I recall the only fix is to replace the entire fuel pump assembly right? I'm currently running a bottle of Techron through the tanks but have serious doubts it will "fix" my problem. Although the truck seems happy to get the treatment though. My Butt-O-Dyno tells me my throttle is more responsive. So now to find the going rate of a pump, I'll handle labor.
Thanks for reading, all thoughts and opinions are welcome.
Try a bottle of Injector cleaner it acts as a lubricant, it helped a fuel pump out of my buddies 98 once. I don't know if you can replace just the float...if I was dropping the tank or removing the bed(the way I do it) I would just do a pump for peace of mind IMO. 03- pumps are prone to failure around the mileage your at now anyways...
I think it's one whole unit you have to replace. Pulling the bed is the way I'm planning on doing it when that day comes...
And when that day comes for me I'm building some sort of trap door over the pump so I ain't gotta pull the bed the next time :lol:
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
Trap wouldn't work on my crew cab. The sending unit is under front edge of the bed. I plan to raise the bed. I've dropped tanks before...no thanks. Now the fuel Gage drops off when idling too. Also doesn't jump up either just creeps up as I drive.
So what is so hard about dropping the tank?
My 04 impala does the same thing luckly i can acces the fuel pump from the trunk and I don't have to replace the whole pump just the fuel level sensor for like 40 bucks did some research!
It's just a PITA...done it both ways. Only did the tank way once, lots of four letter words.
You can have a bed off in about 10 minutes as long as everything goes right. Just need a couple buddies to help lift. Droping tank and trying not to twist lines off is a PITA.
Correct me if I'm wrong but on his truck their is only 8 bolts holding the bed down. And your light wiring harness and trailer harness to disconnect behind the rear bumper...pretty much it.
Had to drop the tank once because it was on a truck where I use to work that had a service body on it. What a joke that was dropping the tank...
Not to mention 9 time out of 10 your pump will fail on a full tank. 25 gallon of gas in the tank setting on your chest sucks lol.
Had the bed of my 11cc was very easy, 8 bolts i think and some wires and 3 screws for the filler neck. I removed the bumper also just so i didnt scratch anything
Sent from my ADR6400L using Tapatalk 2
Yeah I wish I could pull the sender and smack it around a bit. Still haven't done any price searching but that stupid idiot light is annoying the crap out of me.
  • 3 weeks later...
So I did some researching and found the all the pumps I found for my truck do not include the fuel level sensor...really???
So what I buy a new level sensor and a pump??? Ugh!
The truck still starts and runs just fine so why replace if the replacement doesn't include the very part I need?
Has anyone successfully pulled and repaired just the fuel level sensor or am I just asking to "beat a dead horse" per say?
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
