3.6l DI No Start issue (Traverse)
splat10
Posting this here becuase i think the technical aptitude on this board is way better than the traverse forums. original Forum link:
http://www.traverseforum.com/index.php?topic=2347.0
Issue: Car won't start in very specific circumstances.
Original Post: 12/27/11
This thread is a little similar but not the same issue i think. http://www.traverseforum.com/index.php?topic=1980.0
Within the last few months when it's gotten cold (upstate NY) we've had two instances of our 09 traverse not starting. Both cases the traverse was parked outside for a few days (while i did other stuff in the garage). The driveway is inclined away from the house if it matters (and might). I started the car long enough to pull it into the garage (less than 10 seconds probably). The next morning the car wouldn't start. Cranked over for a long time and nothing. Eventually, after cranking several times for more that 5-8 seconds it started an ran fine. All other times it fires right up.
Any thoughts? Fuel pressure regulator? Fuel check valve? It's starge and I know about turning on the key and letting the pump prime and listening for that. Did that and it didn't help. Since i can't replciate it there's nothing the dealer can do as there's no codes stored either.
New Post: 12/26/12
So this happened again this morning. This time it was VERY difficult to start. Backed it out yesterday for about 2 hours. When i was done in the garage i pulled it right back in. I do this often in the warm weather as well and have had no issues. Wife tells me theres about a half tank of gas this morning. It took a very long time to get it to catch this morning. Garage is not heated but not extra cold either (attached). When it did catch the idle was VERY high (about 3000 rpm) for about 10 seconds before settling down and it was fine.
Maybe it's a christmas thing since i posted this exactly 1 year ago, and haven't had this problem again since. Battery is strong (as it was able to crank the engine for a long time). I told the wife to fill it up and dump in a can of seafoam just to make sure there wasn't any ice crystals in the gas lines but i don't have any other ideas.
Any thoughts? It's not really a problem, but would like to solve it from happening again.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
