It's not really a problem. It is just how the motor runs. Remember even the gen 1 & 2 small blocks used about a quart every 3000 miles.
I picked up a 06 8.1 in November and have put close to 11k miles on it since then. Drove it from WA to GA, and changed the oil from dino to synthetic. It had burned maybe .5 quart in 4000 miles. I then turned around and drove from GA back to WA. I now have close to 7k on the Mobil 1 and am not even down 1 quart. I really think it's hit or miss on if you get an oil burner. I suspect a lot of it comes from the early years when GM had a lot of slop and is less after they made the changes in 03(?). I did the back and forth on the 6.0 vs 8.1, and ultimately decided the difference in fuel economy was so minimal that I wanted to be able to tow and not know the trailer was back there.
For what it's worth, my Dad has an '02 with the 8.1 & the Allison transmission.
It's a strong engine, no doubt. However, the transmission is loud, whiny, and clunky.
I'm not a fan, for that reason. He's carried it to the dealer & to a transmission shop, and they have told him it is "normal."
I don't buy it, and am not a fan...
Just my $0.02.
scott
My 4L80 is loud, whiny(straight cut gears),and clunky,but since its a 3/4ton truck and not a Caddy I expected that. What were your Dad's expectations? (this is a question, not trying to be a smart butt). Is this the first HD truck, or is it more hard shifting that other HD trucks that he has owned? I know I have had others that owned 1/2ton trucks comment on the ride & firmness of my truck, but when I explained it they understood.
The reason the Trannys are like that is because the firm shifts = less slipping, reduced wear/heat, and the gear cuts make the overall package more robust. Granted would I like better if it was smoother? Maybe? but part of getting the strenght, is the trade-off of soft shifts. Hope this explians it.
I heard they made changes to the intake manifold bolts in the 2004 MY to solve this problem. Mine doesn't use much oil either and it's a '05.
DEWFPO
I would go with the 2003, soley for the color and fewer miles.
I was thinking the exact same thing. I don't know what it is but the white color does not do it for me, just to plain.
Hopefully I will go test drive them tomorrow and find out more details.
Edited by memory1
I would go with the white one, it does have more miles, but it does not look like it was used to tow a gooseneck or 5th wheel. So it probably only towed "medium" heavy loads 6000-10,000. While the 2003 has a gooseneck ball in the bed, and probably used hard to tow heavy loads. Granted that's just a guess, but most bumper towing is max around 10k, where as a gooseneck and 5th wheel goes up to 16,000. Both trucks are capable of towing up to 16K in the gooseneck/5th wheel configuration, and bumper pull up to 12k.
Hopefully I will get to go tomorrow to look at them and try to find out what these trucks were used for.
Are you sure both trucks can pull the same amount? It looks like the maroon one has a heavy duty trailering package and heavier springs and the white one does not have that according to the specs. The heavy duty trailering package was another thing I liked.
One thing that concerns me is the maroon one was in an accident according to carfax. It looks like it just had damage to the right rear.
One thing I don't understand. Why are some carfax reports free and others you have to pay for?
I found another truck I am interested in. http://louisville.craigslist.org/ctd/3639796374.html
This one does have a few more miles but is also a little cheaper. Is there a big difference between Chevy and GMC?
Edited by memory1
Basically no difference between Chevy and GMC. Most people stay away from vehicles with 5th wheel hitches and overload springs because those are generally trucks that have been used the hardest. However, since the mileage is decent I wouldn't worry about it too much if everything is in order. I've seen babied low mile trucks have tons of issues, and beat to hell work trucks that run fine. A lot is luck.
Edited by kstruckcountry
GMC usually runs a little more expansive new. I prefer the look of the GMC. But that particular try l looks like a good deal. Decent miles on it. Doesn't hurt to go look at it and ask questions
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Good point, I guess the moral of this thread is go drive them both, get the one that seems to be in better shape.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
