going from 17s to 18s or 20s with the max trailer package
limitedz71
Hey everyone, im looking to buy a new silverado and can get a good deal one with a max trailer package. only problem is i hate the 17" rims they come with and asked to opt for 18s or 20s. dealer said there is too much involved with swapping them, ie computer programming and other related issues. and after its all done it still could present some issues down the road. says because of the 373 gears and axle too. is this true or does he just not want to swap my rims?
  • Replies 30
You'll be fine,as long as you stay with the OE tire size for whatever wheel you go with,IE-18" = P265/65R18 or 20" = P275/55R20
They just don't want to swap. My truck package came with 17's. I put oem 20" wheels and tires on the same day I bought it. No reprogramming or any issues.
Sent using Tapatalk
I see tons of NHT trucks with factory 18's and 20's installed on them before they leave the dealer. If your dealer don't want to do it, I'd find a new dealer.
Exactly, if they wont do it, another one will.
A local dealer here last year offered to swap out the 17" LT wheels for the 18" aluminum wheels that were take offs for a upfit.
I think he said $400 would get them swapped out & on the truck.
I agree ^^^^.
Yep, I agree with the others.....it's an easy swap that won't be a problem at all, as long as you re-program the TPMS sensors that come with the new wheels (takes about 5 mins). Sounds like the dealer doesn't want your business that bad.
Also, just keep in mind... I don't know what it is, but there is a reason that the NHTs have the 17" wheel & tire combo. My guess is that the 20" tire doesn't have as much weight-carrying capacity, but that is just a guess. I also dislike the 17" Chevy wheels, but put the 17" GMC wheels on mine... I had the 18" OEM Z-71 wheels, and just wanted something different. Good luck finding what you want, it should be a buyer's market, particularly the closer we get to the 2014s coming out!!!
It is a weight rating thing; GM is pushing towing capacity, not the fact that NHT is a thinly disguised ass-kicking performance package. The weight rating of the 20s is only about 100 lbs less per tire than the 17s; nothing to worry about in non-tow or most tow situations.
I swapped the 17's on my 2010 NHT to a set of the 18's off a Z71. The only thing I had to do was recalibarte the tire pressor sensors. The wheels are basically the same overall size, I could not see any difference in the speedometer or the tachometer at any given speed. I was checking with my GPS before and after the swap.
http://www.silveradosierra.com/gallery/image.php?album_id=430&image_id=7508
You lose 400 lbs in capacity. Depending on what you haul or tow it may not be a big deal
I swapped mine with the 18" Z71 Wheels, but went with the next size taller tire. I just had my local garage swap the TPMS over from the 17's to the 18's.
ok so now i know i can get the 20s if i want. BUT.. i found another truck thats pretty much a twin to what i am looking at, and it has the 20s and 6.2 just not the max pack with the 373s. so do i settle for 342s or try to get the dealer to throw 20s on the max truck? i dont really need the max pack for towing but always liked 373s.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
