"Revised" 6-speed
"Powertrain grade braking is now included in all six-speed automatic transmissions. This feature reduces brake rotor temperatures 100 degrees Celsius on grade tests by downshifting transmission gears, thereby reducing brake applications on long downhill conditions."
After reading up on grade braking, it appears that this feature is now active whether you're in Normal or Tow/Haul mode. However, I'm not sure if that's what I'm experiencing b/c the DIC isn't giving me any indication (on the GMT-900's a message pops up indicating when it's happening). They say if you press & hold Tow/Haul button for 3+ seconds it deactivates it... I'm going to test that out on my way to work.
  • Replies 54
Update: pressed and held Tow/Haul button a few seconds then released. DIC indicated Grade Braking Off. Transmission still rough downshift when braking, so that wasn't it. Looks like I'm back to Wait & See until 2500 miles.
Yeah dic will let u know when it comes on. I get that every day going down the. 1-10 bridge here locally.
My 04 Acura tsx has this...tap the brakes on a down hill and it will put in hill descent....its trans programming is way ahead of my 09...my 09 will free wheel down a hill requiring one to use brakes or drop in to manual and downshift...and 5-6000 lbs. going down a good hill can really get rolling...
GM hasn't been a tech leader in any sense for the last 50 years unless you count Delphi magnetretoricial(sp) shocks. GM owned them at the time.
Its mind boggling when you think of the incredible stuff they did in the first half of the automobiles existence, and then..... it turned into a giant corporation.
MotoMedic: Have you noticed if they corrected the shudder problem caused by checking the O2 sensor? There was a TSB for the 900s that under decal around 40-50 mph it would check the O2 sensor and if interrupted by giving gas etc could cause a shudder. I think it checked the sensor after every restart??? My 09 has problems with bucking on such a decal.
... Totally normal. ...
I get goose bumps when I read quotes like that regarding to problems with a GM product...
so long
j-ten-ner
Normal operation of a transmission, or any other vehicle system, is not a problem just because its operational characteristics are different than what you perceive to be as normal.
Your 4 speed was not a clutch to clutch transmission like the 6 spd is. Totally normal.Not sure what you are saying as I am not a tech...my 09 does not do this but it does buck on decal around 50-40...ops seems to rev to high on down shifts?
ALL GM 6 speed automatic transmissions are a clutch to clutch transmission that means absolutely no slippage or freewheeling on downshifts. I'm sure certain years are different than others and I'm sure certain vehicles are slightly different than others due to ongoing calibration changes and owner driving habits. I'm not driving the op's vehicle but considering that I deal with these vehicles everyday on an above dealership technical level, my opinion of what he is describing, is a normal operational characteristic of that transmission.
I guess you did not quite get my point.
But anyway in a late model truck I would never "always trust the instruments" more than my butt...
so long
j-ten-ner
so long
j-ten-ner
Then maybe you, like many others these days it seems, should get an engineering degree (if you don't already have one) and go to work for GM calibrating their Powertrain components. They are hiring for those exact positions right now at their proving grounds.
Yesterday, I used the Tow/Haul mode for the first time pulling my boat. Grade braking kicked in coming down an overpass and I have to say it's a nifty feature. Also, when on the boat launch, the Hill Assist kicked in and my truck/trailer didn't roll back, even an inch, when I released brake to hit the gas. I really like this feature! On my old truck, I'd hold the brake with left foot, rev up a bit with right foot, then release the brake to stop from sliding back towards the water.
I don't think what I'm experiencing is due to the type of transmission, but is instead due to when the transmission chooses to downshift. If you've ever driven a manual, you know downshifting early will cause the revs to jump up b/c the engine is suddenly forced to match gear/wheel speed (that's why racers blip the throttle on downshifts). I believe now that GM intentionally uses low-level engine braking at all speeds/grades, and just increases the amount when you're in Tow/Haul or on a steep surface. I understand why they would b/c it does reduce braking required. I've just been slow to adapt, and given the choice, would rather use my brakes to provide 100% of the stopping force. But it is what it is... like the poll I posted on the new trucks name, I'm probably just being too OCD! ha
I do appreciate everyone's feedback and I'm really glad we have a sweet a$$ forum like this one when questions arise! :thumbs:
Grade braking is on all the time to some extent unless turned off by holding the tow/haul button for five seconds or using the manual shift mode. Had mine kick on this weekend when driving in very hilly terrain, cruise set, no tow/haul mode and no load on the truck.
Also used the hill start assist to pull the jet ski out of the water this weekend. Defiantly handy for sure.
The normal, no code, bucking and jerking of my 09 on decel from 50- 40 mph is just my perception not the pos trans and programming, now I understand. Been to dealer many times on the matter.
They're hiring? Is there a demand? Too many complains in the past?
so long
j-ten-ner
Edit: Sorry OP. No further disruptions.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,377 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
