"Revised" 6-speed
  • Replies 54
The normal, no code, bucking and jerking of my 09 on decel from 50- 40 mph is just my perception not the pos trans and programming, now I understand. Been to dealer many times on the matter.
I have seen this complaint on all truck related forums or news sites from all half ton & up mfg's over the past 2/3 years. Have not noticed my truck doing the same or anything out of the ordinary. Would imagine the base cause for the issue is programming designed to force the trans in the highest gear possible at the lowest rpm for the hags at the EPA.
MotoMedic did you can tire size on the stock 20 rims I see you are running 33'.Might ask the GM tech if it allows for tire size changes in the ECM.
I would spend extra if they would put the Allison in the 1/2 tons. It's the best shifting transmission built.
An HD trans in a light duty truck would drive horrible. Too much parasitic loss.
I'd recommend not altering the ECM. Assuming your speedometer is 100% accurate with factory tires, switching to 33's will mean at 75 MPH you're actually doing 77.5 MPH. And as the tires wear down, your speedo will only become more accurate.
I know in my old GMT-900, after about 15k miles on my 33's, my speedo reading was identical to my Garmin at 75 MPH.
  • 1 month later...
From a GM employee:
"What you are probably feeling with your coasting downshifts is that we are leaving the torque converter applied during the shifts. We do this because if the trans is backdriving the engine, the engine can reduce the amount of fuel the engine is getting to make fuel economy better.
The shifts should get a bit better in feel with miles, but will probably not get to the same feel (or lack of feel) that an older truck may have had.I can not go into any more technical detail than this without losing my job, but suffice to say that what you are feeling is not something wrong with the vehicle. Hopefully your comments are more that the truck is 'different' than 'bad' in this area."
Yep, first in class MPG #s. Drivability issues? Yes we give you those too. Even after, Justin and an 89 oct tune, my 5.3 still bucks on decel around 45 mph etc...my friends 5.0 ford has no such issues. His 5.4 did not either and I drove it a lot.
I have 6500 miles on mine. These transmission issues will go away, or at least mine have.
Please keep the feed back coming. I am very leery to drop coin on a '14 an still have a drivability issue like my 09.
I had similar feeling w/ tranny "shudder" it has since gotten progressively better over time/mileage. I now have 3,600 miles and it should be getting used to my driving style. When I find a tuner who can give me a quality engine/tranny tune while installing some 3.73's I'll be happier.
Have to love trading driveability for fuel economy in a truck. :rolleyes:
Best said yet!
I have 1300 on mine now and it really does adjust to your driving style. I came from the awful Ram 65RFE, so right from the start I felt the 6L80 was much better than my old truck. For anyone complaining, go drive a Hemi Ram with the old 5/6 speed, and you'll look forward to getting back in your 2014 GM truck.
Feel much better about the '14 drive train after my 2nd extended test drive. Shift up and down was a lot like my Justin 89 tune and you could feel the extra T/Q and some hp as I keep the revs low. will report some more later in a thread,
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 980 Guests (See full list)
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
