Installed Hayden Transmission Cooler
So, I might be the only one on this board that didn't have the trailer package on their truck when they got it. I really wanted to get a tranny cooler put on. On my GMT-800 I got the GM Accessories package which included the OEM tranny cooler and OEM lines. You had to replace the line that ran from the cooler to the transmission. This was a royal pain. Plus, the damn things have a limited service life as they started leaking after some years. With this in mind, and the fact that the install procedures for the OEM tranny lines on the GMT-900 included bumper removal (for the line that runs from the cooler to the transmission), I decided to go aftermarket. The Hayden 677 plate cooler fit with room to spare. By drilling a couple of holes in the mounting plate of the cooler I was able to bolt it in front of the AC condenser without a problem. I didn't want to use those stupid zip strips with which you mount the cooler directly to the fins of the radiator/condenser.
I purchased two of the Hayden 106 transmission fluid lines (made by Gates), which you will need if you install one of these as the hose which comes with the cooler is too short and too narrow. Also, the Hayden 397 cooler fitting adaptor works perfectly to plumb the cooler into the radiator.
Basically, if your truck doesn't have a tranny cooler it is no problem at all to install this. Took me about an hour. Make sure you pick up two of the 106 lines and the 397 adaptor and you'll be good. You'll need a couple of 1/4 inch bolts from a hardware store to securely mount the cooler itself. After all was said and done I had to add just shy of another quart of fluid to the tranny to account for the additional lines/cooler.
I figure if I have to replace the Hayden lines after a period of time I'm still no worse off than the OEMs which tend to leak anyway.
All was purchased on amazon.com
Already transmission fluid temps are running cooler in summer city stop and go traffic.
When purchasing I noted that the 677 was still larger than the OEM external cooler on both the GMT-900 and GMT-800 trucks. I didn't want to take up too much space in front of the A/C condenser. In the Hayden catalog the 677 was listed as the middle of the line up. Now as I look at things though, I might swap up to the larger one!
No trans cooler here but once I put one in it made a world of difference.
I was running a large TCI cooler last year, it would eventually get into the low 180s temp-wise in August as the days went on. So far this year, the Tru-Cool, while driving, has only hit 158 degrees F...if you sit for a while, it creeps up, but drops back down once you start moving again. This is in South Texas heat-humidity, and as August approaches, that will be the true test.
Its been upper 90s here for a month with high humidity and without towing Im at 155 all day no matter how hard I run it.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
