Trouble finding parts online... 2000 3/4 ton (LD)
Hey folks...
having some trouble/confusion searching for parts online to fit my truck.
I've got the gmc 3/4 ton LD from early 2000 ( 3 door ).
Everything I come across is for the 2001 HD model... and nothing for a 2000 3/4 ton on most webistes.
I even had one guy from the live help section on the rough country website tell me they had no suspension lifts to fit my truck because the "fram" lol... is different.
maybe I should be searching for 1500HD from the same year?? as I understand they are basically the same.
looking for tips/help/comments.
Also... looking for someone on the forum who has a 2000 LD 3/4 ton I could share ideas etc with.
thanks.
Thanks for the reply.. not exactly sure what to do yet.....My main goal is to get rid of the rake.. and I don't intent on putting much larger tires on it ( 285 or 305 max ). I know this subject gets beat to death but I read mixed reviews about the t-keys and the stress they put on the bars... I may just save up and do it right with a suspension lift... still debating so all comments welcome.
there are a few pics in the photography section if you'd like to look and then comment.
thanks
I personally wouldnt want to put that much money into an older truck. have you tried just cranking the stock keys?
youll be fine putting keys on it.. i ran keys on 2 trucks over 150k with no issues
The keys haven't been touched as far as I know... I don't think the old copper was into the level look ;) Funny thing is... found a "royal reserve" whisky label stuck to the inside of the dash lol... damn cops
I work at a tire plant and get a limited supply of free tires so I'm going to be saving a ton when it comes time to re-skin !
I'm appreciative of your comments but am still somewhat reluctant to crank up the keys...
haha. your perfectly safe to crank the keys, just dont crank them all the way and max them out or it will ride like crap. make sure if you do it though jack up the front end and get the front tires off the ground.
you can always crank them back down
sorry , connection was sputtering there...
what am I going to get out of cranking up the bars... 2"- 3" ?
enough to swing 285's on the stock wheels?
I measured it and I need about 3" to be perfectly level.... I'd be happy to get 2" or 2.5" .. would take most of the rake away... agree?
this may not be on topic but I'll ask you first since we're chatting...
I noticed today that my oil pressure gauge will fluctuate when I accelerate ... it moves from about 275 kpa to 350 kpa .. ever have this happen... or is it normal... oil level is fine.
Oil Pressure will fluctuate depending on the RPM of the engine, perfectly natural.
If you have a 99 or 00 2500 in the door jam sticker it will show the max weight at 7200 lbs or so, the first two years of this body style were lighter weight trucks than the old body style trucks of those years. The old style had a weight of 8600 lbs. I hope this helps, also you will have the 6.0 l motor in your truck if it is a 2500 and that did not come from the factory in any other trucks those two years. :jester:
Jim,
thanks for the reply but I've already figured that part out... the problem Ive been running into is when searching websites for various parts ( leveling kits/ susp lifts etc )... it's a model that seems to be lost in the shuffle .. kind of a crossover thing I guess.. when you search for 2000 gmc 2500 .. the only thing available..on most sites is the 2500hd (01)
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
