Anti-freeze flush
I know you can test your antifreeze to see if it's still worthy of using, but what are people's thoughts on performing a replace/flush. I have a 2008 z71 sierra 4x4 ext cab......with 75K on it. I try to stay on top of maintenance....so curious what folks normally do.
That seems a bit early to me. I think its good for over 100k but that's when I did a complete system flush and changed hoses.
I'd flush it, no matter if it says go to 100k miles. Coolant issues can be easily prevented by having clean coolant and a cleaned system, water pump, etc. Cheap preventive maintenance I think.
Flush it now. Been in there at least 5 years. Consider replacing hoses at this time as well
Get it flushed, I'd recommend using dex-cool extended life antifreeze with distilled water (pink/purple cap). I'd stay away from local Speedee & Jiffy-Lube all makes extended life and any cooling system cleaner and conditioner.
Just did mine before I traded it in. I had 88K miles on the clock, but noticed that the coolant was starting to congeal on the bottom of the radiator cap, so I figured it was time.
I snapped my heater hose and used a Blast Vac gun to purge the system. Put the T in the heater hose, refilled with Dex, and distilled water, and was done in a little less than an hour.
A Blast Vac gun looks like a pistol, that you hook a garden hose and an air line to. It comes with multiple fittings to fit into various size hoses, etc. I ran it at about 20-30lbs of air pressure (no more, or you'll blow a water pump gasket!). It forces the water through the system, and when you're done, you can shut off the water and just run air through it to clear everything out.
last weekend I did mine and i do it every year
and be sure to purge all that air out of the cooling system
With no cap to leave open, How? And do you just pop a hose to drain and flush?
Get yourself a Lisle Coolant Funnel Kit #24680. Napa also makes has thei same thing with their name on it. It comes with a bunch of adapters to fit all the different radiator/coolant tank appliactions. Stick it on your coolant tank, and fill from there. Start your engine, fill the system, then fill the funnel up to within a few inches of the top. As your cooling system fills, you'll see the air purge itself and the bubbles will come up thru the funnel. I leave it for about a half hour, maybe less. Once the air is purged, you plug the funnel, remove everything, dump out the funnel and you're good to go. As far as flushing, you could do it a few different ways. Like I said above, I snap a heater hose and stick my flush gun in one end, and stick the other end of the heater hose into a bigger hose and let it drain into a big old container (that I can take to my buddie's dealer and dispose of). Not sure if it's the best way, but it's worked for me for a bunch of years so I stick with it. Hope this helps.
No one should think it is ok to run the 100,000 on their coolant, unless they put 100,000 miles on their truck every 3 years. Yes yes yes it says in the manual that it is good to 100,000 miles. And while it may LOOK good, by 60,000 miles it has lost much of it's protection and is starting to damage things. This goes for any extended life coolant, not just Dex Cool. DexCool got a bad rap in the earlier days and rightfully so, but mostly because people did NOT maintain their vehicles properly, and thought they could get to 100,000 miles without having to worry. ::buzzer sound:: They were wrong. So was GM. DexCool has been improved over the years but if you want to run 100,000 miles on your coolant or not change your spark plugs until 100,000 miles, do at your own risk.
Dealer told me that all the fluid changes and coolant flush are not required until 100K. I have my sons Silverado with 51K all fluids changed coolant flushed with brake and steering. Was told no need dont waste my money.
Well i worked at a dealership and saw the issues through the years. So my vehicles get items changed constantly. As someone stated earlier cheap maintenance compared to the possible issues.
Will be doing my other 06 silverado with 47,900 miles at 50K. Got my sons truck all completed with flush coolant, PS Fluid, B fluid and all fuilds/filters changed for out the door after tax 800. No need to worry about it for another 50K.
Didnt think about the plugs. So what plugs to put in AC Delco or other? Gap is?
yes Sir,
here is how I did it
turn heater all the way (no need to turn the blower/fans on)
remove the lower radiator hose, then remove thermostat and just install T-stat housing (don't supper tight those bolts)
refill with just tap water run the engine till its warm and flush (i do this about 3 times)
now install everything back and refill with 50/50 mix Dexcool
install reservoir tank cap <<-- don't tight all the way
start the engine
keep filling the reservoir while its warming (1 to 2 min) <-- don't run until over heat or water boil
shut off the engine
fill or make sure you have dexcool 1/2 inch above cold/full mark
now install reservoir cap really good
run the engine until pretty hot or rad fans kick in then stop the engine
wait till everything is cool - back to normal
add fluid if needed
I would flush and replace the anti freeze every 40-50k, NO MATTER WHAT GM SAYS IN THE MANUAL.
:thumbs: Even if you pay to have the work done by a shop, a 40-50K interval for a cooling system service is a good idea. It's not that expensive compared to what you may have to pay to have done if you use the GM schedule in the owner's manual (My 2008 book shows 150K). But the manual also says that depending on the use a rig gets can change the frequency of service.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
