2006 gmc sierra 4.8 4X4 no crank
Ok, here we go. My neighbor has a 2006 GMC Sierra 4.8 4X4 that he was installing a " tornado " fan in front of the MAF. Started the truck and forgot to plug the MAF back in prior to starting the truck. Said the truck started, ran like crap, then stalled. Now wont crank at all. There are no codes stored in the PCM, no signal to the starter, and the headlights and gauges do not dim or drop when you turn the key to try to crank it.
Also, this trick is a base model with no security system so there is no exciter ring for the key. Any ideas?
I've swapped the ignition relay, tapped on the PCM and ignition module to no avail.
Battery is new and has been checked and rechecked, starter has been removed and checked and all show good.
Also, when you jump the starter with the ignition on, the starter spins but doesn't crank the engine. Still, autozone and o'reillys say the starter is good.
Ok. Now being told he has a bully dog system on the truck as well that plugs into the PBS 2 connector that was plugged in when the truck stalled. It wasn't when I went to check codes on the truck of course.
Still not sure why it wouldn't have thrown a MAF code since he started it with the MAF unplugged
Never mind. . . I got it. The dumbass ran the "tornado" into the bottom of the fuse block under the hood and it acted like a generator and over amped the under side of the ignition max fuse , welding the contacts together and shorting the relay to where it stayed open.
Yeah. This guy wants his 4.8 4X4 to be some "hot rod" and lays all these aftermarket electrical wires over the motor, pinched in the door jams, plugged in to just any location that shows power with a test light and wonders why he is always having to come over to me to get it running again.
He has the odasity to think that it's something that I'm doing to his truck.
Folks, if you don't know what you're doing. . . Please don't mess with it
Tornado :rollin:
What a waste
Come on dude, I saw a guy with two installed and it netted him 100hp and 120tq to the rear wheels!
You only get that if you install a throttle body spacer too. :lol:
That was already on before those.
The only thing those things add is voltage and amp drain. If the little fans aren't spinning, they suffocate the air intake to the point the MAF will throw a code and the truck runs like crap. Not to mention, if the installer runs wires over the engine, through door jams, power plugged into wherever he can find 12 volts. Never mind if it is on a fusible link, amperage specific, it plugs them into both terminals where a fuse was supposed to go.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
