Dumb moves by big rigs.
SnakeEyeSS
There are none too bright in every profession. While the trucking industry moves america, there are some real doozies out there. What have you seen?
I just saw an oversize load swerve so his cargo wouldnt hit the traffic light. The Cargo was shorter than his exhaust stacks! :lol:
Saw an oversized load making erratic lane changes on I44 yesterday looked like the load had shifted a little as well.
A couple of weeks ago saw a dump truck use the shoulder to pass a couple of cars after the on ramp he used to enter the highway had ended.
Sent from my DROID RAZR using Tapatalk 2
One idiot driving a semi up here missed his turn on US85 and decided it would be a good idea to back up.
At night.
Some poor guy came up the road and hit the back of the semi at full speed, killed him instantly.
You can really see some amazing things up here in oil country.
A driver here blew his right turn and ran the trailer into a utility pole. Rather than back up and go again he just kept on going forward skipping the container around the pole. awesome.
I have my own.
A couple companies I worked for would let me practice with their rigs, so I took the offer when I could. I was learning how to drive one of these things about 14 years back. I was doing some laps in a parking lot down by the docks in Seattle and after about 10 min or so my buddy decides I'm ready to go... I still can barely shift this damn thing... but whatever right? I get onto the Ballard bridge and stall, miss shifts, lurch the rig, pure awesomeness. All this during peak rush hour. Hell yeah, I backed up traffic for at least a mile.
I see them on their side all along the highway every winter. My friend drives truck and he said you only get a few weeks of training before you can be considered a driver.. And the people training only have a few months.. It's pretty ridiculous that this is allowed especially since you are out in the road.. Hell look how many years of college you need to be in any other profession.
Look how little it takes to get a regular license. I mean who here has had official training since driver education when you were 15-16? I know I haven't yet I can hop in the seat and drive to my hearts content. At least CDL drivers have logs to maintain and in theory prohibit driving for too long.
Paper logs prohibit nothing until you get pulled over people lie in them all the time that's why they are putting electronic ones in. Once they are mandatory everywhere alot of truckers will be unhappy.
That's why I said in theory.
yea, those Mansfield bars are hell on vehicles..
Lloydminster Alberta yestarday at 0430 hrs a cavalier with 6 kids ,aged 13-17 blew a stop sign and a tanker semi t-boned it and put in in a slough (slew) ,and the truck was on top of it i think ,,,,killed them all,except the trucker
the area is a little in shock over it
ya ,not good ,news this AM says there was no ejections from the car and no seat belts ,,,,,,
when i went to high school about a million yrs ago west of Toronto ,a car full of kids went flyin down this straight road and got air over train track,the road turned slightly and when the car landed it hit a rather large stump and put the engine in the back seat ,killed everyone ,,,,nasty
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 458 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
