2012 HD Problem with Dash Gauges
While driving the other day, I stopped for coffee. I got back in, buckled seat belt, started truck and noticed blinking seat belt dash light would not go off. I rebuckled seat belt and light continued blinking. I put it in gear and drove off. The tach froze at about 2000 rpm, speedometer stayed on 0, all other gauges locked up. The odometer miles did not change (I drove about 15 miles), the compass said South but I was as heading East. All other electronics seemed to be working and engine ran fine.I called OnStar and they ran diagnostic and found nothing.
When I reached my destination, I parked and shut off the truck. About 2 hours later I started the truck and all gauges were normal and everything has worked fine since then.
I have 38500 miles on the truck and have never experienced any problems before.
Has anyone ever heard of this happening?
Govtech4, thanks for the reply. Are you familiar with this issue?
I have driven a few hundred miles this and hasn't reoccured. Steve
It may have been one of those things that, because the current vehicles rely so heavily on computers, simply needed a "dude-dude-reboot-reboot!" to get everything reset.
I was thinking the reboot thing myself. Since it hasn't reoccured, I will just assume that.
I know yours is a 2500. I have a 1500, but mine did the same thing about 4 months or so ago. I was driving and noticed my seatbelt light was on even though I was buckled up. While driving, I unbuckled and re-buckled but it kept flashing. Then I realized the tach and speedometer weren't working either and the odometer wasn't increasing though I had driven about 20miles. I continued home. I shut if off and when I started it back up it was fine. Hasn't done it since. It drove fine the whole time as well.
no,ive been outa the dealer life for 5 yrs thank god ,could be a one time thing ,thou making a service visit under warranty for the Cover Your A** thing cant hurt either lol
I'm at 39k miles. Out of bumper to bumper warranty. I don't believe this issues would fall under 100k/5 year powertrain warranty.
sorry ,i forget to do the KM to Miles conversion lmao !!!
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
    • I bought the truck new in December 2022, and it's got 60,000 miles. The front cover magnet had slightly more glitter, but overall very clean, no off odor, and good-colored; really nothing to report. My truck has Hi-Lo transfer case, and the fluid looked great, as well. I have towed..maybe 1,000 miles. Yes, this was the first change for all three driveline items. I'll probably do the transmission at next oil change.
