Need a Fair opinion on guys towing with the new 5.3l
nards444
Boost is only there when your on the gas. When your idling or just cruising along you should see decent vacuum...
Sent from my SCH-I535 using Tapatalk 2
  • Replies 61
nice videos. I test drove a chevy the other day with 3.08, no nuts whatsoever, I dont know who would buy that set up. Im guessing 3.42 and 3.73 will be much better.
Also the max trailer option is not available yet to order but is in the system. Dealer tells me he thinks the ability to order it will be soon.
I tow 8-9k about eight to twelve times a year and the 6.2 (3:42) would be my recomendation as a minimum. As mentioned earlier the NHT tow package on the 5.3 or new 6.2 will make all of the difference. Since your trips are short the 5.3 should do fine with the 3.73's. Do not get the 3:42's with the new 5.3 if you need to max the towing, it will do the job but you will probably be disapointed.
Dealer Im working with can see the NHT package but can only put it on a 50k LTZ. So he either doesnt know whats going on or there is an issue. GM said when I called you can order them as of today. Might be a software glitch I dont know.
After the run around yesterday. Its true the 5.3l can not be ordered yet in NHT. According to GM the 5.3 has been available for a while now, and GM wanted to build and promote their 6.2l. This was just BS with the guy on the phone. Why the 6.2 only in LTZ I dont know. But with a 6.2l all star edition, 4x4 and crew cab it was 50k. Well for that Id take a platinum or diesel.
  • 1 month later...
I have a 5.3 CC 3.42 short bed and tow a 7,000 lb horse trailer. When I get over 60mph I wish I had a longer wheelbase to keep the sway out of the trailer. My 2,000 lb Clydesdale likes to move around back there. Power and braking are fine.
Thanks I didnt get the short bed I ordered the standard or bed. Ordered the truck around SEP 26 or something I got a call last week while on vacation and the truck showed up, havent been able to talk to dealer or go look at it. I have to go in and look at it, run the numbers and see if it makes sense.
Ok picked up the truck last night got the max tow package. Ordered 27 SEP and it showed up last week and I picked up this week. So far the truck is a very smooth ride. The interior is very nice and miles ahead of the old model. As far as towing that will have to wait. One thing to not currently the NHT or tow package can only be ordered with the LT1 or LTZ 1 no Z71 or suspension package. I was also told you can not order with the all star package, which I dont if thats 100% true or not, either way I got the convience package and 18in wheels come with the tow package.
Can you clarify that a bit. Did you get the 5.3 w/ max tow and 3.73 gears? If so, what's the payload rating on the door sticker?
yes its the 5.3. You can only get max tow with the 3.73 gearing. You can also get it in the 6.2l as well which is like the LTZ high country or something. ID have to check the door jam but I beleive its right around the 2k mark
Need pictures of the new ride! I'm curious about the actual payload, as this is the first max tow 5.3 I've heard about.
Ill try later tonight. I ordered the first time it was available and before they even went down the line. They started production on OCT 14th, so Im assuming the option is not as big as they thought at least right off the bat.
I didnt check the door jam last night, but verified the windo sticker and it has the 5.3, 3.73 gearing, and 9.76 rear end as I ordered it.
  • 3 weeks later...
w/5.3 and max tow (3.73) max trailer is 11200 on a 15753 (double cab std box 4x4).
Slightly different for other box/cab combos. Slightly more for 2wd
+1 Gotta look at the payload inside the driver's door jam. Tow weight is secondary to payload. It's the yellow and white sticker with the tire sizes on it.
I own a 2011 5.3 CC 4x4 and I am a magazine editor that does a lot of pickup towing tests/reviews. If you want honesty, the 2014 5.3L will still struggle compared to the 6.2L that's coming out in 2014s.
I'd recommend the bigger engine because if you tow your boat a lot, the bigger engine will provide better mpg and towing prowess than the smaller V-8. You can also order the Max Tow package, which will come with 3.73s. The axle is different (bigger/stronger) in that option.
Regardless of engine, get a weight-distributing hitch for your boat trailer if the trailered weight is more than 6,000 pounds. (yes, there are a couple companies that offer W-Ds designed to work with surge-brake trailers.) The setup will not help mpg/power, but it'll do wonders for stability and control.
2014 Chevy Silverado 1500 Review
Thanks for the information. I tossed around the 6.2 but with all factors considered its a poor decision at least for me. Like I said I tow that load max 10-12 times a year tops 40mins one way both on roads going 60mph with gently rolling terrain one way and flat the other. No doubt the 6.2 will give added power but then again your still talking about a 1/2 ton put a diesel in a half ton its still going to tow like half ton.
Really when you factor in the cost of the 6.2 having to get it in a top trim level, the fact that my MPG will suffer the other 350 days of the years, its really a bad call. 6.2 in general IMO is space manufactures have tried to fill from guys wanting 3/4tons but cant afford or dont want the cost of upkeep on them, in the end Im not sure you get that much capability.
I appreaciate the information specially on the WD hitch. Truck is already bought. I just went from an eco which in my book for half a ton towed like 10, and I expected some downward progress but didnt want to go from a 10 to a 5.
    Smitty462
    Smitty462
  • Who's Online   4 Members, 1 Anonymous, 693 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
