Finally cleared headlights
thanks guys next on the list will have to be a bb tune and maybe different wheels. my wifes gonna kill me lol
Lol. I literally just mentioned wheels to my wife. Her exact words were, "I'll kill you!" She didn't feel that way when I bought her a new set a few months back!
Truck looks sick!
+1 and to the above...cleared head lights looks very nice. may have to steal that one. friend has been telling me to do it, as he did it on his 300 srt8!!!
Dang, that looks freakin sharp! I love the blacked out look.....but just wouldn't be able to keep it looking nice as my daily driver.
  • 1 month later...
I don't know why gm doesn't just install cleared lights that orange makes headlights look awful.
it was not GM's fault, but D.O.T.it requires all vehicles manufactured/sold
in the US to be equipped with amber corner reflectors, and red tail reflectors..you can buy them already factory cleared, but only from over sea's where it is not required.
Great looking headlights and truck. I have to agree, the taillights are too dark for my taste.
Mike
I have yet to see that written anywhere. Please post a link.
Standard No. 108 - Lamps, Reflective Devices, and Associated Equipment - Passenger Cars, Multipurpose Passenger Vehicles, Trucks, Buses, Trailers, (except pole trailers and trailer converter dollies), and Motorcycles (Effective 1-1-68 for vehicles 2,032 mrn (80 or more inches) in width and Effective 1-1-69 for all other vehicles)
This standard specifies requirements for original and replacement lamps, reflective devices, and associated equipment. Its purpose is to reduce traffic crashes and deaths and injuries resulting from traffic crashes, by providing adequate illumination of the roadway, and by enhancing the conspicuity of motor vehicles on the public roads so that their presence is perceived and their signals understood, both in daylight and in darkness or other conditions of reduced visibility
http://www.nhtsa.gov/cars/rules/import/FMVSS/
if you look in each state's motor vehicle code you will find out about required reflectors.. not being an A$$, it's just the law.. :)
I was serious when I asked. Still don't see where it says that amber reflectors are required up front????? And believe me, I'm well aware what Texas requires, and it isn't on our books. In fact, in Texas it only requires that turn signals up front emit an amber or white light, or color in between amber or white, but no reflector requirement. My rig passed inspection no problem too. If there truly is a requirement for reflectors up front I want to see it, which I've yet to. Thanks for the link though.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
