Well, she's finally done! here is my ride!
Is this a 1/2 ton All terrain???
Sure is 2014 All Terrain.
6.2l
8' BDS Lift W/ 20' XD Riot wheels wrapped with 35' Mickey Tompson Degans
Custom True Dual Exhaust
K&N Intake
Throttle Body spacer
Edge CTS Evolutioin 4 stage programmer
Aftermarket Grille
2015 tow mirrors
Tinted Headlights
Bull Bar.
26' RTX LED Light bar (Bull bar Mounted)
Rigid Industries LED Lights in Fog light housings (Also Tinted)
Tinted Tail lights (Not to Dark) with Reverse lights left untinted.
Tinted 3rd LED Break light
Real Time GPS Tracker/Blackbox with backup battery with a 2 month life span when main battery is disconected.
Hidden Kill switch to prevent theft.
Edited by RDU053
6.2l
K&N Intake
Aftermarket Grille
2015 tow mirrors
Tinted Headlights
Bull Bar.
Sir, you have one hell of a ride. I love black because when it's clean, it is so pretty. But it will show every mark known to man after a while. My car is black and I've had it for 10 years and I still find scratches and marks I don't remember ever seeing. Lololol. Plus Texas Heat is a whopper with black cars.
Haha thank you! Yes, Black is very hard to keep clean. You get the texas heat, I get the Salt, and snow :D But I dont mind getting er muddy. I try and keep it as clean as possible though!
I hear ya man!!! I can't wait to get mine traded and the other one ordered. I will be seeing more snow as soon as we move to Colorado though.
Couple pics after a bath and the new tires:
That color combination is spot on man. Looks great! I like how you shaved the tailgate too, smoked taillights/headlights aren't my thing, but truck looks great.
Thank you!
I had the tails painted, was really worried about going to dark again (was pulled over in my last car for this). The light shines through these just fine, but I think they are a tad too dark again. I have a backup set that I am going to bring to the painter and see if he can go lighter still.
My last debate for now is:
1. Leave Silverado in Chrome on Side
2. Plasti Dip it Black and Put Glossifier over it, so it's gloss black.
3. Remove it all together
Thank you!
Black it out! it would look sick, i had them done on my 2010
Leveling does so much for these trucks.
2015 LTZ Z71
2 1/2" RC lift w 2" rear blocks
295/60/20's on stock rims
Line x bed liner
Extang tri-flip hard tonneau
AFE performance cat back
MIT intake tube and high flow filter
dee969d270ada2e6dbf359d013ee8c5c.jpg7085d1cdb3063990ada6fc9a08d03764.jpg39de23ea71cd524577bad2a8e7ff2240.jpgf7928badf3f27cf739f92bfd36ac351b.jpga3d36b296d91ebc5bf5dd940c204290e.jpg7f82cb24100e8bcfbdf84a29e1fe6a72.jpg
  • Like 4
Thank you!
I vote to remove all together. You really don't have any black gloss items that it would accent with. I think a matte black would look better than the gloss since it would at least match the side steps. But these tracks really have such beautiful side profiles that removed would look best IMO.
Still need to get around to pull mine, did you use an eraser wheel to get the gunk off?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
