What? You must be selling this or are leaving out some details. Your telling us you picked up 7 mpg with a tune? I think you are trying to make it sound better then it is by using your stock city mpg (14.1-15.1) and comparing it to the highway mpg after the tune (22). You aren't going to find much more mpg from these things, stock they are tuned so heavily for mpg and reliability it is hard to find mpg let alone 7. Compare apples to apples please to not mislead people. Your truck stock should have done 22 mpg highway. Are you running E rated tires?
Tyler
theres always that one guy on the forums.
This was a apples to apples comparison, same route everyday to work 120 miles round trip. Highway and city mix. Before tune on this trip I got 14.1 -15.6 mpg. Same trip after the tune I got 19-22 I can post pictures of the cluster if you want! I Dont sell anything I was just telling him.
Diablo lew tunes, arent a performance chip or a "one setting fits all" tune. Its a program you log data and send to him and he creates a specific tune for your truck using data collected by user. (knock retard, air fuel mix ration, shift timings anything and everything). He changes everything from A-Z to make the engine more efficient. With the correct add ons to your truck he can tune it even better. Lots of people have had similar results to me but most drive with a heavier foot since it has more power but drive it in normal use and you will get similar results. Im not telling the guy he can expect 22 mpg like me by any means as for the environment plays a role in that but if he lives in oklahoma I would bet $100 on it he would get the same mileage as me!
Tires are toyo open country 33x12
http://diablewtune.com/
do your own research.
here is one under testimonials i found
MPG: Before:12.8mpg, now with tune:17.1mpg (wow!)... 0-60 2WD: Before: 8.2seconds (bone stock), now with tune: 7.8 flat... I also run a few dirt drags on a 200ft dirt strip... Best 0-60 in 4LOW has been 5.4seconds! Awesome job man!!
– Codi W.
Edited by nkd90
Thanks for the heads up! I don't want loud exhaust either, what did you go with?
MBRP 3" Cat Back, Single Side Exit, AL its a little deeper on start up and idle than the stock exhaust (just a little, not much) and down the highway or high RPMs you cant hear it at all! Get the performance without the noise! double whammy!
Got my towing mirror installed and wired up! Way better than the stock little ones if you ask me! especially pulling my 28ft car hauler!
PS install took me 3 hours, I figured it take me 30 minutes but its never that easy right!
looks good. were they plug & play (turn ,power, heated ) ?
was plug and play up to a point. I had to hardwire running lights, cargo lights, and the reverse led lights but yes power, heated, and turn signal all work. I just had to find the correct wires to tap into for the extra features towing mirrors have.
2015 silverado 1500 LT 7-9" McGaughys lift, 22x12 American force burnouts, 325x50x22 nitto trail grapplers. So much done but so much more to do. "The Never Ending Project"
Sent from my LGLS992 using Tapatalk
Starting all over again, out with the 2014 and back with a 2016. This time I stepped down from the SLT to SLE, so it has a few less options but I don't mind yet but I'll admit, I enjoyed the heated steering wheel and the mirrors angling down. So far I have only tinted the front windows to match the rear and some how the muffler fell off so it now has a 3" pipe in place but the butterfly valve is hose clamped open and the resonator is still in place.
In case anyone is interested,
2016 Red GMC Sierra 1500 Crew Cab 6.5' bed
New guy here. Learned a lot here by browsing around. This is my 2016 Sierra Elevation in Iridium Metallic, just added the 4" Westin nerf bars, carbon fiber GMC badge covers and some Sportsman's black seat covers. 4.3, with flowmaster 40 and deleted resonator.
looks good. would those Westin work with gm molded mug flaps ????
I would think so, they don't come close enough to the front to be in the way of them. I'm definitely glad I got the 4" steps, my big boots wouldn't do well on any smaller.
I couldn't resist the year-end deals and bought a Sierra 1500 SLE. I've already added a spray-in bed liner, bed cover, step rails and Weathertech mats.
Edited by kurt1305
looks good . good deal - xmas package
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
