posting peeve
idahoruss
  • Replies 37
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Nice
Oh. We control that. If I tell it not tp say that then it wont appear in my post. For you not to see it, everyone on the forum using Tapatalk would have to shut it off
yze5uqa2.jpg.......
Sent from inside Chris's van.....
Nice wheels on that van! Park that van out on the street on Halloween, and you'll have a bunch of kids lining up. Probably would even if it wasn't Halloween..... :)
First time we brought the van out in a while. I got tired of black Suburbans following me
Honestly thought of getting one that hasn't been registered in forever with the last known owner dead or mia and park it in front of a school to see what happens.
Oh okay, thanks. No wonder I wasn't finding it! Oh well. :lol:
Why don't you call in a bomb threat while you're at it and then sit in the van so I can see what happens.
Sent from my high horse.
Where is the fun in that. Really. That's just a dumb thing to do.
Sent from the Great White North
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
