posting peeve
idahoruss
  • Replies 37
The user can turn it off. Like I have. But FYI, sent from my iPhone 5 using Tapatalk. :lol:
Its a setting on each persons device.
Sent from my Samsung Galaxy S4 using Tapatalk Pro
+1
Sent from my Coke can connected to the Interweb via string
So this member opens a post about how annoying tapatalk messages are..... IMMEDIATELY 5 people post replies......with tapatalk messages!! hahaha you guys are funny i'm in though :smash:
Sent from my Iphone using unbelieveably irritating Tapatalk
Most of us use Tapatalk to access the forum. I like the message there so I know where I posted from. Also if there is a mistake I can blame it on my phone since the GS4 doesnt have auto correct
I have it and dont use it. I dont want to re-teach it the words I use off the forum.
How do you turn that off? I had the same question, but didn't know it could be turned off.
It will just turn off for your device so you will still see it in my posts
It kind of is
Sent while handing out free candy in a windowless van
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
