Looks almost "low profile" compared to others that seems to look like police light bars on trucks.
Sent from my iPhone
Wow have they gotten really popular around my house geez. Seen a new white Z71 with roof mount light bar 50" look like and they put quad led pods in the rear bumper step. I should have taken pictures.
I don't like it sticking way up on the roof. Its right on top just right above the wind shield. Has anyone but LED lights on the bumper or right under the bumper?
I had custom headlights made with rigid diffused d2s in the high beams. 79e37d036faf9ca876c7e6830247ebba.jpg
Who did your headlights? I really want mine done.
Thelightingfirm look them up on instagram. They were priced only 200 cheaper than plainNsimple1. Who is the best in the US. Also check out Ecotint on instagram he does some wicked builds. I will be selling these and i have stock non projector heads i am selling cheap as well.
Your selling your custom headlights you had done? Why? Pm if you want to see them. Would like more information.
For light bars behind the grille, has anyone considered using the Rigid Industries Cradle mount for a 30" bar? It looks like they are suppose to be mounted vertically but I don't see why it couldn't be mounted horizontally. This is what I'm talking about: http://www.rigidindustries.com/mounting-options/43010
The slots in this cradle mount could line up with the cross bracing in front of the Radiator. Only thing is I don't know how tall this mount is... Might not be enough room between the grille and the cross brace for it.
Added my bar today. The Grill on the High Country was easy to pull. 4 10mm bolts on the top, and then just pull the tabs up and out.
I used eBay pods. They costed me $80 for all four of them. The bracket is from Rigid Industries. I didn't see the Point in paying Rigid over $400 for the same lights. I have had both on previous vehicles and there is no difference. My cheap eBay lights have lasted just as long as Rigid's. Hope that helps.
Sent from my iPad using Tape talk
The output is nowhere near the same.
Is there an ideal angle or adjustment to these? Right now, my spot light from the light bar is hitting the tree tops, so I know I have to angle the light bar down, just not sure how much? Should I park the truck a couple hundred feet back of a large wall and aim that way?
I would say that's the best way to align it.
Can you get some night pics? Been wanting to do this
Sent from Tapashit
Sent from Tapashit
I'll do my best to snap some in the next few days. I turned the light on tonight while going thru a forest preserve and it lit everything. Very happy with it
Added my bar today. The Grill on the High Country was easy to pull. 4 10mm bolts on the top, and then just pull the tabs up and out.8765b6e09927227b56a3adaec53c4710.jpge0101ccbd5bed985e3ae06173cab5968.jpgf4a69d859d38f3fc0a1ff34c579219fb.jpg
Just an observation, that light bar is mounted blocking the airflow over your oil (trans?) cooler.
Looks like a PS cooler. Not needed for those of us with electric PS..... :D
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
