http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035'>http://www.gm-trucks.com/forums/topic/163073-lights-behind-grill/?p=1509035
There it is but I looks like its obstructed a lot unlike the gmc where u have more space!
As soon as I get my 22" bar in and installed I'll post some pics for you.
that's a LT grill.. I think if I get a light bar behind the grill, I don't think you would see that much light come through.
Rigid leds everywhere
That looks very nice but I'm sure it set you back a few bucks.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I was looking at strictly rigid for my 15 sierra slt but just can't spare that much money right now. Lol. Looks very good though on yours.
I find that anything other than rigid is just Chinese made but...off-road led bars olb is a good company and pretty much about close in quality as rigid. Prices are more reasonable
I'm looking at one the kerrs light is using. It's a curved 30" bar to go behind the grille and I'll probably go with that one. But I'm definitely going with d2 driving for the fogs.
I have the same grille but am going with the Rouge Racing "Rebel" front bumper with Rigid's 40" RDS bar instead of the fog light kit. Just waiting on the funds to hit my bank so I can pre-order the bumper since they haven't released it yet.
Edited by sailor9908
i hear you i was looking at rigid but its way to expensive for me. i started to look around and i seen that rough country makes light bars too. yeah i know they make suspension parts but they do have a 3 year warranty on it.
I'm a huge fan of Rigid lights, but for what it's worth, Baja Designs is a much better product. Dollar for dollar they beat out the lumens on every size (bar or pod). They also did some extreme torture tests to compare the two side by side and BD beat Rigid every time. Just saying.
Josh
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
