Which one are you using?
I got the totron one. Has on/off, s.o.s, and nine different flash patterns
Do you have a link? Can it work with any brand light?
I had one on my truck and it only lasted a few months before it shit the bed.
just ordered my OZ USA light bar for my grill, can't wait to get it and install it :)
so does a 30" - 32" light bar fits behind a grill with NO problem ??? I think a dual row will be the best (straight) ?? Any information will be helpful. Thanks
A 32 inch bar will fit behind the grille with plenty of room. I have a 32" curved double row. You will have plenty of room for it
Sent from my SM-G925V using Tapatalk
Thank You.
Thank You.
Lets see some pics when you post put a bar in the grille
I ordered the double row 30" curved light bar and ill try and duplicate the brackets that kerrslight made for his...they shouldnt be too hard to replicate
Let me know if you have any questions when your installing it. The measurements and getting everything lined up in the hard part. Mounting and assembling is easy.
Hope you enjoy the bar!
may I ask were you order from , and the make . Thanks
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 550 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
