Ohhhhh....interesting. windshield was hardly dirty. Where is the module, in front center ahead of the rear view mirror?
Sent from my DROID RAZR HD using Tapatalk
  • Replies 37
Top Posters In This Topic
It's right below the mirror. Also keep in mind if the roads are covered in snow, the sensor won't be able to pick up the lines.
Mike
Edited by mzodarg
Nope...wasn't the roads fault. I still think this system needs improvement.
My sensors act up all the time when its below zero even when the truck is spotless.. The sesnors don't like the cold..
- Al
I have zero issues with mine, works as designed.
Mike
same here
at least it is small and mostly un noticeable. the 14 subaru outback system looks like the thing at the bowling alley that projects the score on the ceiling in front of you,it's huge.
Had the same thing here 2014 Silverado 4x4 Crew LTZ Z71... Drivers side front sensor goes off intermittently ...finally parking sensors displayed shutoff message
...then the weather here in Boston warmed up and the sensors are working like normal again.
Right from moment one when I picked up my truck the front center sensors always show that I am right up against something or will shutdown the park assist. 2014 Denali 6.2.
I'm surprised it seems so sensitive with the cold weather...amateurish on GMC's part.
My 6 month old Silverado is also giving me the warnings as well, clean or not. Mainly, whenever it snows the slightest bit falls in front of me. I guess it doesn't want me to hit the flurries. I asked the service rep just now about it and he "never heard or this before me" seem like I am always the first one to complain about things. I tried turning the sensors off but they reset themselves every time I restart the truck.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,479 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
