Have the same problem on my 2015 silverado, it always seems to be when it's cold out. It has been -35 oC here lately. took it in three times. They couldn't replicate the issue. Finally I used my phone and sent them a video of it. They ordered me sensors. I get it back tomorrow I will let you guys know if it's fixed or if I have the same problem. I
  • Replies 37
Top Posters In This Topic
Posted Images
Right from moment one when I picked up my truck the front center sensors always show that I am right up against something or will shutdown the park assist. 2014 Denali 6.2.
As have mine!! 2015 1500 ltz z71
  • 10 months later...
I've had my 2016 Silverado for a week now and today's snow has made my front proximity sensor go haywire. Did anyone have any luck when taking their vehicle into the dealer? If snow and ice cause this system to malfunction then it is not a robust design.
My 2016 front right sensor goes off all the time when thwre nothing in from of the truck. I took it in already and they said they can duplicate it.
I took a few videos to share with them. It's almost like they are pointed too low and that react to the road.
Mine did it once in the rain... Hasn't done it since... But I have only had the truck for 45 days
Sent from my XT1254 using Tapatalk
Dealer can't fix the weather, and no they won't work when covered.
"These detection distances may be
shorter during warmer or humid
weather. Blocked sensors will not
detect objects and can also cause
false detections. Keep the sensors
clean of mud, dirt, snow, ice, and
slush; and clean sensors after a car
wash in freezing temperatures."
  • 5 years later...
i haven't seen an actual fix mentioned. my issue is a little different. my rear sensors just stopped working, no messages at all.  camera comes on when put in reverse but no warning sound. also the light on the switch never lights though when i cycle it it does say i've turned it off.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
