If you build yourself make sure you solder the wires to pins. I have some extra parts because I ordered in bulk. I'm selling already built and pinned with braided shielding for $45 plus shipping. I figure it's the same price as a dealer but with better wire, shielding and already pinned and color coded for ease. Also I ship the next day after payment. If you want to build yourself I'll ship all parts for $25 plus shipping and ship next day. If you buy my harness I'll provide support for any wiring you need.
I also have an option to build on a relay so you have inadvertent discharge battery voltage. I build a Bosch relay and diode into harness so it supply you with battery power that the bcm turns off 20 min after the last door trigger with the key off or to prevent battery discharge. It protects you from forgetting something on and killing your battery. If I can help anyone, let me know.
It's cheaper to build your own but my harness is soldered on every connection with 600v rated contractor grade braided wire and braided anti friction shielding. If you damage it or have an oops I'll repair it. I warranty for 30 days but as long as I have materials to help you, I'll repair in good will.
I treat every item like it's going in my truck and I don't delay shipping. I have materials in stock and pre order when I get low. I sell quite a few of these and will discount for anyone ordering 10 or more.
  • 4 weeks later...
I might be interested....If your still here Daniel tuck.
Sent from my XT1254 using Tapatalk
Yessir.
Pm with name, mailing address, model trim and year of truck, email address to send PayPal invoice and your phone number. I have a few ore built ready to ship.
  • 2 months later...
PM Sent. This looks like exactly what I need. Thanks!
  • 1 month later...
Yessir.
Pm sent
  • 1 year later...
Does anyone know what fuse feeds pins 7 and 17 in this picture?  I'm trying to get the 12V constant to switch a relay for lights and I'm not getting any voltage from either.
This is in the x61 junction block under the left-driver's foot.
Edited by papageoff
Changed pic
  • 10 months later...
Thanks for all the info in this thread. I got the ignition ON/OFF for my P25 radios and my other radios.
I used an old brake controller wiring harness to get the plug in leads to make my ignition sense wire.
  • 1 year later...
Would anyone know the size of the female spade that fits the posts in the fuse/relay box behind the brake pedal? Having a hard time finding the right size female spade. TIA
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
