2500HD 6.0 Cold Start
2011 2500HD 6.0 gas
19,000 miles
Every once and a while I will get a clacking at start up thats very brief. Is its something I should be concerned about? It goes away very quick, under 5 seconds.
I use mobil one synthetic every six months which is about 4,000 miles
thanks
Matt
I've been around engines for years and this is normal behavior.
DEWFPO
That's normal for a gas engine, It takes a little time to get the oil up to the top.
I use a new PF48 each oil change
Thanks for the responses.
Once its running, it's good. I am also getting a constant "chick chick chick" once its warmed up. Cant tell if its the injectors or bottom end. I may bring it in to have it looked at...
-matt
2011 2500HD 6.0 gas
19,000 miles
thanks
Matt
This may be what is going on...can't say 100% but...
You may have a vehicle with a concern of cold engine tick noise.
This concern will diminish within 50 seconds of a cold start.
The noise shuts off like you have flipped a switch.
This concern may be a vehicle design characteristic as the ECM calibration is designed to meet cold start emissions.
The noise that you hear is actually combustion taking place in the exhaust manifold. When the timer hits the 50 seconds it advances the timing and the
noise is immediately gone
-matt
My 5.3 and the last two 6.0's I had make/made this noise. Normal far as I can tell. Many others I've driven do it as well.
i have the same issue on my 12 2500 Hd 6.0 keep me posted on this if you happen to take to the dealer. my dealer has never been able to duplicate,i only have 10 k miles on it and its done it since new, i use dexos GM oil and the gold AC delco filter.
  • 3 weeks later...
Do you guys get a tick tick tick tick from your bottom end when the truck is warmed up? Sounds like an exhaust leak almost. I don't wanna waste my time bringing it in if it's normal. It's like a loud injector almost.
Thanks guys
Matt
Going to the dealer with it Friday. I also noticed when I start the truck in the cold cold, lets say below 15-20, I will get a humming in the engine bay about 5 seconds after the truck is running. The humming will last about 5 seconds.
The day I'm going it's not going to be super cold so I'm just going to mention it to the service manager. Plus I have to get the truck there in the morning.
matt
Hey Matt,
How did your dealer visit go? If there's something you would like us to look into for you please reach out via PM including your full name and contact information, VIN, current mileage, and involved dealership.
Sincerely,
Jonathan A.
GM Customer Care
Dealer could not duplicate the tick when warm nor the humming when cold start in extreme cold. The cold snap broke the day I brought it to the dealer. So next cold morning I'm gonna get it down there and for them to hear
Matt
