VIN
I have a 2002 2500hd with the 8.1 liter big block. I bought it used with only 3500 miles on it. The question I have is will the VIN tell me what the axle ratio is? The guy I bought it from said it is the 4.10 ratio but I want to be sure. The VIN is 1gchk23g02f199391. Thanks for your help!
Look in the glove box at the RPO codes.  If you see a GT4 then it is a 3.73 gear.  If you see a GT5 then it is a 4.10.
If you cannot find the build sheet do what I did, I went to my local GM dealer (Canadian)and with my VIN # they gave me a printout of the RPO's for my 96 GMC 2500HD.
You have a GT4 (3.73) and a G80 (locking) rear end.
Here are all your RPO codes (alphabetical order);
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - SIX-WAY POWER PASSENGER SEAT
AJ1 - SLIDING REAR WINDOW
AM7 - FOLDING REAR SEAT
AN3 - FRONT BUCKETS WITH POWER ADJ. AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B71 - WHEEL OPENING FLARES
B85 - BRIGHT BODY SIDE MOLDINGS CMD - ASSEMBLY PLANT - FLINT, MI
C49 - ELECTRIC REAR WINDOW DEFOGGER
C6W - GVW RATING - 9,200 LBS
C60 - AIR CONDITIONING
DF5 - W/OUTSIDE TEMP & COMPASS
DK6 - OVERHEAD CONSOLE
DL8 - EXT REMOTE CTRL HEATED MIRRORS
D07 - CUSTOM FRONT FLOOR CONSOLE
E2C - ORDER TO DELIVERY - EXPEDITE
E63 - FLEETSIDE BODY
FE9 - FEDERAL EMISSIONS
FT2 - ARM TORS BAR SPRING ADJ
FT3 - ARM TORS BAR SPRING ADJ
GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE
HVY - IDEN 2 INCH BODY RAISE,HD MODEL
JH6 - 4 WHEEL POWER DISC BRAKES, HD
KC4 - ENGINE OIL COOLING SYSTEM
KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K68 - 105 AMP DELCOTRON GENERATOR
L18 - VORTEC 8100 V8 MFI ENGINE
M74 - ALLISON 5 SPD AUTOMATIC TRANS
NF2 - EMISSION SYSTEM, FEDERAL TIER 1
NP1 - ELECTRONIC SHIFT TRANSFER CASE
NP5 - LEATHER WRAPPED STEERING WHEEL PCM - ELECTRICAL CONVENIENCE PACKAGE
PDD - COLOR-KEYED CARPET
PY0 - 16 X 6.5 ALUMINUM WHEELS
QIW - LT245/75R16/E OOR BW TIRES
R9Z - POMS AUTO SEQUENCE
SLL - SOLD ORDERS T96 - FRONT FOG LAMPS
UE1 - INCL 1 YR SAFE & SOUND PLAN
UP0 - W/SEEK-SCAN, TONE SELECT,
UQ3 - ENHANCED AUDIO SPEAKERS
UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
VB3 - CHROMED REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE PKG.
V73 - STATEMENT OF VEHICLE CERT.-U.S.
XGK - LT245/75R16/E OOR BW TIRES-FRNT
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO YGK - LT245/75R16/E OOR BW TIRES-REAR
ZGK - LT245/75R16/E OOR BW TIRE-SPARE
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
Z85 - INCREASED CAPACITY CHASSIS PACK
1SC - * ROOF LUGGAGE CARRIER
1SZ - 1SC SAVINGS W/SUNROOF & CD
39U - INDIGO BLUE METALLIC
6GL - FRONT SPRING SELECTOR LH
7GL - FRONT SPRING SELECTOR RH
92I - DK PEWTER/DK PEWTER INT TRIM
922 - EZSPEC
